Author Topic: help me pick wheels!  (Read 28341 times)
Offline xCaliC10x
  • BMW Witch Doctor
« on: September 25, 2010, 02:01:48 am »
Ok guys. I wanna keep my truck kind of low key and stick to 15's. They are more low key, tires and wheels are cheaper, and I like an OEM look. I'm debating between this style with flat caps, and maybe rings....
and this style with caps and rings.....
on this......
I do not know what lowering kit is on it, but was told it has spindles and springs, and it has an axle flip.
What wheel and tire size should I run? I have been told I can squeeze 15x10's in the rear. I want the tires to fill out the fender wells close to the lip. I can/will get them rolled if I have to. I have been flipping through picture threads and I see all sorts of wheels, van wheels, 7's, 8's, 10's, all different tire sizes. I have no idea what to get and can't really return a set of wheels and tires if they look wrong or don't fit. Help!!!!!
'80 C10 short bed 350/SM465, Edelbrock carb/manifold/Elgin cam/custom headers/magnaflow, flip kit, spindles/springs.
'09 328i coupe sport package. Magnaflow exhaust.
'11 335d diesel 425ftlbs, 27-30MPG city, 40-44MPG hwy.
Re: help me pick wheels!
« Reply #1 on: September 25, 2010, 10:03:08 am »
You definitely want 15x10 in the rear 15x8.5 in the front. Measure your backspacing you need and pick the style you like. As far as tires break out the tape measure and see what you have for clearance. You should be able to fit a 325/50/15 in the rear
Offline Swims350
    • Cars and trucks
« Reply #2 on: September 25, 2010, 01:21:13 pm »
I think either wheels would be ok, but I like the centers for the 2nd better, and trim rings for sure on either. Maybe the corvette or camaro centers? but personally I think I'd leave the wheels you got on it now, I like aftermarket better. If you like stock then go for it.
www.cardomain.com/id/benwa454
Offline xCaliC10x
  • BMW Witch Doctor
« Reply #3 on: September 25, 2010, 06:33:41 pm »
Definitely leaning towards the truck centers and caps. I just need to get a few confirmations on the sizes, backspacing, and tire sizes from you guys on here which know more then I do. I'm waiting to hear back from Stockton wheel on Monday if they have the right sizes in stock or I have to buy some craigslisters and ship them off.
I HATE the wheels on it. They aren't for me, or the direction I want to go. I basically want my truck to look like a factory built muscle truck. When I take them off I will sell them. I have no idea who makes them, or what they are even worth. Any ideas? Also, what drop do you think it has inch wise?
4859528562_2dd8eb88a9_o by vwman70, on Flickr
I am also going to be swapping out the square lights for round.
« Last Edit: September 25, 2010, 06:35:44 pm by xCaliC10x »
Offline Layne
« Reply #4 on: September 25, 2010, 07:02:17 pm »
Maybe a 3/5 drop?
Offline Swims350
    • Cars and trucks
« Reply #5 on: September 25, 2010, 07:35:35 pm »
round lights definately, what drop it has on it now looks like 3/4 or 3/5 look under the back and see if the leafs are under the axle or on top. if they are under it's flipped and is a 5-6 drop depending on who you talk to. if not then I bet it's hangers and shackles which is a 4 inch drop, but I think can be made into a 3 inch on some shackles by moving the leaf down a hole?
truck centers work good and sound good to me, I think the ones with the most holes or the 2nd pic would work best, they came on trucks, but the others look good as well. You want painted wheels or have you considered chrome rallys?
As for selling not sure who makes em either but you can find it out, see if the center has a name on it, or if you have a tire took off it look at the inside sometimes they are stamped.
I think they are decent wheels, I've seen worse, I'd think $200 for a whole set, maybe give or take $50-100 depending on where/how you sell them. if you include tires and they are good tread left I think more like $300 min. to maybe $400-500?
If it was me I'd go for a set or cragars or TT-2's
Offline xCaliC10x
  • BMW Witch Doctor
« Reply #6 on: September 25, 2010, 07:58:57 pm »
The springs sit under the axle.
I have Thought about Cragars and Torque Thrust styles, they are still an option. They look period for the truck.
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #7 on: September 25, 2010, 08:08:32 pm »
I like the slots with the center caps of the 2nd set. My 2 cents...
Offline Swims350
    • Cars and trucks
« Reply #8 on: September 25, 2010, 08:48:04 pm »
my old man has the cragar ss's on his 84 c10 he has the reversed offset or deep dish ones in a 15 inch. I love em.
I would like to see the first wheel with the 2nd wheels centers.
Offline 1980c10
« Reply #9 on: September 25, 2010, 11:32:26 pm »
looks like a 4/6 drop. corvette rallys might be nice for a period understated but nice factory "muscle" style wheel.
Offline xCaliC10x
  • BMW Witch Doctor
« Reply #10 on: September 26, 2010, 04:57:20 pm »
Ok, so I found a set of the earlier Corvette Rallys, in chrome with flat caps, 15x8 front, 15x10 rear 4 1/2 back spacing came off a 70 C10. Thinking of going to pick them up. Guy wants a fair price for them, so I may go get them, 1 1/2 hour drive, and its 101 degrees out. I will take my car.
Offline xCaliC10x
  • BMW Witch Doctor
« Reply #11 on: September 26, 2010, 05:09:58 pm »
Also, I want to run a tire in the rear with some sidewall to give it a good rake, nothing insane, but I don't want low profile on the rear.
Offline xCaliC10x
  • BMW Witch Doctor
« Reply #12 on: September 26, 2010, 08:51:41 pm »
Thanks guys for your help. These are MINE! 15X8 4"BS, 15X10 4.5"BS They are true and straight, stamped made in USA, and came with flat caps, $380....
Now for tires and round headlights.
Offline Swims350
    • Cars and trucks
« Reply #13 on: September 26, 2010, 09:37:06 pm »
nice wheels a set of all chrome rallys. I think I'd like a different center but those look good.
I think you want a 295 or wider rear tire maybe a 295 75 70 or 65 not sure what size you can get. I think I've seen a 295 60 and 50 but can't remember. I'd go to summit and check out their tires to see what sizes you can get. Maybe a 315 or 325, or some old school n50's or something like that.
« Reply #14 on: September 27, 2010, 05:40:49 pm »
I already made a suggestion for the rear tire... but you need to measure the front. I have 265/50R15 on the front of my 74 and 235/60R15 on the front of my stepside. Those wheels are 5x5 lug pattern?
