Author Topic: vapor lock  (Read 4394 times)
Offline 77 cc lb
vapor lock
« on: September 29, 2010, 01:36:16 pm »
anybody have any any good ways of preventing vapor lock on fuel lines? thanks for any info.
87 Chevy crewcab shortbed soon to have a 454/400
Re: vapor lock
« Reply #1 on: September 29, 2010, 02:01:55 pm »
carbureted or fuel injected? Keep them insulated from heat. Vapor lock means the fuel has boiled which is caused by heat and pressure drops.
Offline 77 cc lb
Re: vapor lock
« Reply #2 on: September 29, 2010, 03:43:44 pm »
it's carbed. would the foil tape be enough to help keep cool?
Re: vapor lock
« Reply #3 on: September 29, 2010, 09:05:53 pm »
It shouldn't be boiling unless the tank isn't vented and the lines are too close to a heat source.
Offline 77 cc lb
Re: vapor lock
« Reply #4 on: September 30, 2010, 06:00:11 pm »
thanks vile. i made a bracket for the fuel line to sit off the valve cover, which i think was the problem.
