Author Topic: how to mount mirror  (Read 5479 times)
Offline Buddy
how to mount mirror
« on: October 01, 2010, 05:33:46 am »
now that I was able to get the door to fit. I see that there is no holes in the door for the morror to bolt on. Just looking for any info or tricks to do this. Where can I buy the hardware. I tried to get the nuts out of the old door but they looked pressed in.
Re: how to mount mirror
« Reply #1 on: October 01, 2010, 06:02:14 am »
Nuts, and bolts work fine. You can also get rubber mounter brass mounts. About a 1/2" hole, when you tighten the bolt is expands the rubber out to hold tight in the hole. If you want the original style you will need the rivet gun with the nut sert attachment, and nut serts. Make a simple pattern, and messure to place the new holes.
« Reply #2 on: October 01, 2010, 10:30:09 am »
There is a measurement in the tech section for placement.
« Reply #3 on: October 01, 2010, 01:01:09 pm »
You need 1/4-20 jack nuts.
Just google them. The factory style had a coating on them.
http://www.drillspot.com/products/1011419/approved_vendor_0162801_mirror_mounting_with_sealer_jack_nut_pack_of_25?s=1
You can find them from Dorman as well and in the HELP! section at most autoparts stores.
http://www.jegs.com/i/Dorman+Products/326/45820/10002/-1
« Reply #4 on: October 01, 2010, 07:21:09 pm »
Jack nuts are what I have always known as nut serts.
« Reply #5 on: October 01, 2010, 07:24:31 pm »
Nutserts are the rubber ones
