Interior & Equipment
Power Windows & Door Locks
Power Window wire question
Topic: Power Window wire question (Read 13998 times)
Harmon
October 03, 2010, 07:05:38 pm »
This is hard to explain, but I know it must be a common issue...
On the passenger side door, one wire has come off the metal tang that goes into the "black" harness that closes up into which the switch pushes into. I could not get the old metal tang to open up to sodder the wire back into it. Im not sure what to do, right now (door panels off) I have to touch the wire to the metal tang inside the black harness box to make the window go down....any suggestions on what to do to fix this..?
Re: Power Window wire question
October 03, 2010, 07:35:02 pm »
Are you talking about the connector for the power window switch?
Harmon
October 03, 2010, 07:40:02 pm »
yeah...the wire goes into the "connector"....I have the connector but have had no luck Opening it up and crimping/soddering it to the wire...
modular93fox
October 03, 2010, 10:34:47 pm »
buy a new connector or go to the junk yard, grab a few spare connectors or a few extra wires. or just keep touching the wires to the black connector to operate the window... few choices.
clint
5.3 4l60e
Silverado - daily driver with A/C,P/W,P/L,TILT, HID projectors & 13.8" Rear Disc Brakes
A poor man buy's it twice
jaredts
October 04, 2010, 05:58:08 am »
The metal terminal connectors can be bought new--pretty cheap. I don't remember where I saw them, but they're out there. Or as mentioned you could go to a junkyard and pull the whole switch connector as a pigtail. I had a hard time finding any that had not already been cut off--apparently a hot item. Finally found a driver's side from a truck that was a little difficult to get into because of door damage, but couldn't find a passenger one. I finally decided to look at some different gm vehicles and found one in an old Vandura van that was the same.
October 04, 2010, 04:47:49 pm »
Just get a new power window pigtail. If you use the search function you will see I posted a link to the very same connector a while back.
October 04, 2010, 04:51:16 pm »
Here I did it for you
http://forum.73-87chevytrucks.com/smforum/index.php?topic=16288.0
Harmon
October 04, 2010, 06:17:41 pm »
awesome thanks!
jaredts
October 04, 2010, 06:29:55 pm »
I would have bought that one, but I wasn't 100% sure if it was the right one. I called the dealer and they gave me the part number, but said it was discontinued and also told me that acdelco wouldn't have it if his computer showed it discontinued. I should have checked into it more but went the junkyard route. Sorry, I didn't keep the gm part#'s.
