Author Topic: Really bad whistling noise.  (Read 13347 times)
Offline Stewart G Griffin
« on: October 03, 2010, 09:27:42 pm »
i have a really bad whistling noise only when moving.   If i turn the fan on full sometimes it goes away completely.   Sometimes it will get softer.
Any suggestions?
Re: Really bad whistling noise.
« Reply #1 on: October 03, 2010, 10:18:09 pm »
Air seal somewhere.   Does it go away if you crack a window open slightly?  My wing window on my 85 started yesterday for the first time...
« Reply #2 on: October 03, 2010, 11:28:36 pm »
It seems to get a little quieter if i crack the window.   But only a little quieter.
« Reply #3 on: October 04, 2010, 03:55:52 pm »
Where is it coming from?  Window, door, floor, AC, Vents?
« Reply #4 on: October 04, 2010, 04:17:03 pm »
Not sure---seems more to the passenger side.  It's LOUD.
« Reply #5 on: October 04, 2010, 04:22:34 pm »
Whistling or squealing? Unplug the blower motor and see if it stops.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #6 on: October 04, 2010, 08:21:54 pm »
alternator bearings?  water pump bearings?  blower fan bearings (already mentioned)?  Or, all the women on the sidwalk actually whistling at you as you go by?
« Reply #7 on: October 05, 2010, 05:33:53 pm »
It basically went away, but i'm thinking it's something under the dash so i'll be checking that.   i don't think it's the blower because if anything it starts to go away if i turn ON the fan.
i know it's not the alternator or water pump.
« Reply #8 on: October 05, 2010, 05:42:19 pm »
If it goes away when you turn it on it's most likely the blower motor. - Very common for them to squeal
« Reply #9 on: October 05, 2010, 06:50:13 pm »
So it moves even when it's turned off?
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #10 on: October 05, 2010, 10:37:05 pm »
you can't turn the blower off---at least not on my trucks.   Lowest setting, the blower still runs very low---something about keeping a positive air pressure in the cab or air circulating or something I've heard like that.
Offline Grim 82
« Reply #11 on: October 06, 2010, 12:10:56 am »
It always runs to keep the plenum dry.
« Reply #12 on: October 06, 2010, 01:20:15 pm »
i.c.---will check the blower fan.
Offline jaredts
« Reply #13 on: October 06, 2010, 01:46:23 pm »
Do you mean the cowl?
Offline Grim 82
« Reply #14 on: October 06, 2010, 02:07:11 pm »
No, I mean it prevents condensation in the box where the fan blows at the heater core, and the related ductwork. Not exactly sure what it's called, but it's a plenum of sorts.
