Author Topic: Shorty/header spark plugs  (Read 33311 times)
Offline 70 beater
« on: October 06, 2010, 02:58:34 pm »
What spark plugs are you guys using with Vortec heads and headers ? The AC Delco plugs fit the old headers o.k. but they're a bit too long for the new headers. I've got to change some of the wire boots also. '76 2wd smallblock with full length Afterburner headers. Old headers were full length Hookers.
Offline sooner
Re: Shorty/header spark plugs
« Reply #2 on: October 07, 2010, 03:56:29 am »
Vortec heads use a .750 reach plug.
These autolite ar 103's are shorter than a conventional plug and a good alternative to the accel shorty plugs. They worked great for me with headers on my 80 camaro.
http://www.summitracing.com/parts/FRM-AR103/
« Reply #3 on: October 07, 2010, 10:26:56 pm »
 ??? The reach of the spark plug is the length of the threaded portion of the spark plug. What would that have to do with header clearance?
Offline fitz
« Reply #4 on: October 08, 2010, 05:12:11 pm »
I have Vortec heads with Hooker Super Competition headers in my Camaro.
I use the Accel shorty spark plugs.
Don't know the part # of the top of my head but I got them from Summit Racing (as Vile pointed out Jegs will have them also).
Ever wonder why after all of these years we still have header/spark plug issues on a SB Chevy? It kills me to have to take a hammer to a set of $500+ headers to make room for spark plug wires.
« Last Edit: October 08, 2010, 09:41:28 pm by fitz »
Offline TexasRed
« Reply #5 on: October 08, 2010, 08:41:55 pm »
Don't know the part # of the top of my head but I got them from Summit Racing (as Vile pointed out Jegs will have them also.
I'm pretty sure it's a Vaughn conspiracy.
Offline sooner
« Reply #6 on: October 09, 2010, 11:49:15 am »
Yeah, im pretty familiar with what the term reach means on a spark plug. The plug you linked to is a .460 reach plug. The plug I linked to is a .750 reach plug which is what the vortec head requires. I just happened to have a set of vortecs in my garage so I snapped some pics to help you out.
.750 reach on left  .460 reach on right
.750 reach plug fully seated= right reach
.460 reach plug fully seated= wrong reach
Offline TexasRed
« Reply #7 on: October 09, 2010, 03:47:30 pm »
I read on the internets that the vortec plug is actually .708 (.750 should work). I got AC Rapidfire plugs, I think #1. I ordered them off a '84 350. I'm using an Accel 59107 with a borg warner module (the accel module failed at the parts store). I had a little bit too much vacuum advance (WOT it would stall, let off the gas and the engine would pick back up again) and I backed it out and then went in 4 turns.
« Reply #8 on: October 09, 2010, 04:59:21 pm »
If I linked to the wrong spark plugs why didn't you just say that?  ???
These are the correct spark plugs http://www.jegs.com/i/Accel+Spark+Plugs/111/P526S/10002/-1
http://www.summitracing.com/parts/ACC-P526S/
« Reply #9 on: October 09, 2010, 05:01:49 pm »
Oh and as pointed out you have the wrong reach but thanks for helping me out wise guy.
Offline TexasRed
« Reply #10 on: October 09, 2010, 05:34:15 pm »
So I need to pull the plugs I have in there now out and put in different ones?
« Reply #11 on: October 09, 2010, 05:37:03 pm »
You said you put in the .708?
Offline TexasRed
« Reply #12 on: October 09, 2010, 05:42:04 pm »
I thought I put it rapidfire #1's, which appear to be .460.  ??? ??? I thought it was a .750 plug. Well, I'll pull one and see. Better to have put one in that's too short I guess.
« Reply #13 on: October 09, 2010, 05:50:12 pm »
Yes better to go shorter than longer!
Offline sooner
« Reply #14 on: October 10, 2010, 03:38:10 pm »
I did back in post #3 my man.
You then assumed that I did not know what I was talking about, so I assumed that you did not know what you were talking about.
If you run the .460 reach plug, its going to start and run but you are going to have some serious performance issues. Its going to want a ton of spark advance to make any power at all, and it will cause the plug to run extremely cold and will eventually carbon foul. I'd go ahead and swap them out for the longer reach plug.
