Author Topic: windsheild wiper issue...  (Read 4931 times)
Offline bravo1616
« on: October 10, 2010, 09:09:55 pm »
I have an 82 GMC K1500, just got it about a month ago and the wipers are standing up when they are off. They go down first, when your turn them on. Anyone know why and what I need to do to fix this the motor looks pretty new. Thanks.
1982 GMC K1500 Sierra Classic 383 Stroker 4" Rough Country Lift
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: windsheild wiper issue...
« Reply #1 on: October 10, 2010, 11:01:38 pm »
there is a cam switch inside the wiper motor compartment that tells the motor to stop when in the down spot.  It seems when it was installed, it may have moved or something.  It is similar to the old points distributor with breaker points.  The cam arm works similar.  Pop the cover off and you can probably figure it out.
Offline bravo1616
« Reply #2 on: October 13, 2010, 01:10:59 pm »
SgtDel,
I'm not sure what to adjust, can you see from this photo with the cover off.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #3 on: October 13, 2010, 04:35:21 pm »
that cam controls when the power turns off.  Something is off kilter.  That cam is telling the motor to turn off at the wrong time.  I would run the wipers while studying the rotation of the cam and try to figure out what it is doing wrong. perhaps a spring has slipped or something.  I can't tell you any more than that unfortunately.
Offline bravo1616
« Reply #4 on: November 14, 2010, 09:21:36 pm »
Update:
Had the motor re-seated and now the wipers are the way they should be.
