Author Topic: New; need some advice  (Read 4469 times)
Offline DrDaryl
« on: October 11, 2010, 06:23:01 pm »
Hello from Jasper, AL.  I've been here a while trying to learn some things, but only one post.  My truck has Freeze 12 in the AC and has done pretty well with it but yesterday the compressor started making a bad noise and appeared to lock up but then started turning again.  I don't think I have a leak as the system has pressure, but it stopped cooling.  Assuming I need a new compressor (its a R4), and the lines have Freeze 12 in them already, would it be best to stay with the Freeze 12 with the new compressor?  Anybody know what type of oil ships with new compressors for our trucks?  Thanks   1986 C10 SWB GM Goodwrench 350
Sean Murphy stage 1 Quadrajet
Re: New; need some advice
« Reply #1 on: October 11, 2010, 08:54:40 pm »
Stay away from Freeze 12 and every other "alternative refrigerant" R134a is inexpensive and effective and won't cause side effects associated with compatibility and oils. Ester is inexpensive as well and readily available with UV dye.
Offline DrDaryl
« Reply #2 on: October 11, 2010, 09:32:52 pm »
So I'll replace the accumulator and orifice tube at the same time as the compressor?  Should I flush out the  evaporator and condensor and how exactly do you do that?
« Reply #3 on: October 12, 2010, 04:10:34 am »
They sell a flush in a can kind of like orange hand soap but it’s in a liquid form and under pressure then you blow out the system with air to get all that soap out and yes your supposed to replace the accumulator with the compressor and the orifice tube
Offline DrDaryl
« Reply #4 on: October 12, 2010, 06:07:23 pm »
Thanks for the help.  I am going to go with R134a.
« Reply #5 on: October 13, 2010, 03:51:22 am »
Welcome from NW Indiana
Offline 75ChevyGuy
« Reply #6 on: October 13, 2010, 07:25:23 am »
Welcome from MA!
