Performance
Engine Builds!!!
Topic: Engine Builds!!! (Read 16969 times)
chevyguy74
Engine Builds!!!
October 12, 2010, 06:09:36 pm »
What kind of engine setups do people have in their trucks? post ur builds!
chevyguy74
Re: Engine Builds!!!
October 12, 2010, 06:24:13 pm »
i have a sbc with vortec heads and a comp mutha thumpr cam. the same build was in the may and june 2009 issues of Hot Rod Magazine. in the article the engine made 403 hp and 428 lb-ft. it costed around 3000 bucks. if u want to do a build like this just ask a question and i'll help out.
screamin86
October 12, 2010, 07:56:19 pm »
Mines a mexico 350 4bolt block bored 040 it had 26cc dish speedpro pistons so I put on a set of 416 305 heads milled 025 550lift springs summit 1103 cam performer rpm intake 600 carb. The same head/cam combo on a 305 pushed my 82ta into the mid 8s In the 1/8th. Just a fun motor for my hauler/dd 4x4.
86 ta:lm7 hot cam boltons
Layne
October 13, 2010, 12:46:34 am »
sb 400 from a k-30 with and edelbrock 2103 cam, nascar rpm air gap, hooker super comps, and a msd system. Has a complementary rod knock and blown head gasket; free of charge
screamin86
October 13, 2010, 01:20:28 am »
Haha nice! Sounds like a runner :p
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
October 13, 2010, 04:29:25 pm »
my '79 big 10 has a 383 4 bolt main, edelbrock qjet, 2.02/1.60 valves, rv camshaft, edelbrock dual plane performer intake. Powers through a th350c to 3.08 gears.
click
here
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
thachevythang
October 14, 2010, 12:57:42 am »
Well I've kinda got several because 1. dont know what I'm doing and 2. I just wanna smoke some tires and embarrass anybody I can with my little sleeper!!! Can you believe they make fun of my 85 shortbed??? I take that personal!!! LOL
358 purchased turnkey locally with edelbrock top end, thumpr cam, shorty headers, and chrome dress up.
350 block, comp cams mutha thumpr, cyclone intake, edelbrock carb, still in the works
AND what I'm going to post next, questions on a stock LQ4. Heard they are the same as LS engines got a killer deal couldn't pass it up. Has harness minus alternator, starter, ac comp, and ps pump.
'85 SHORTBED
1980c10
October 14, 2010, 01:36:14 am »
250 cid Inline 6, need I say more? 0-60 in about a 2 minutes (downhill). The six actually has some cool points; however, going fast isn't one of them.
going to be a 350 with vortech heads and the usual add ons and hopefully a serpentine belt set up.
still in the planning stages-so taking any and all recomendations.
it needs to be somewhat budget friendly and just a fun driver.
hey chevyguy74 what carb are you running and what kind of mpg's ?
choptop
Extended cab fanatic
October 14, 2010, 06:53:18 am »
I have too many trucks to go into detail, but basically 1-305(stock),2-350s(crate motors),1-400(stock), 1-427(balanced and blueprinted, much more), 1-454(stock), and 1-468( large oval port heads, 280h cam, keith Black pistons, 750 Edlebrock.)
three8six
October 14, 2010, 02:56:34 pm »
A 4.3 v6, bored over .30 recently rebuilt....headers, everything else factory slow as you would imagine...I just got the motor for near free and I needed to put something in there....
CoggedBelt75
October 14, 2010, 06:53:08 pm »
A tad long, but here is mine...............
BLOCK: 383 4 Bolt Main
Align Bored
Deck Surfaced 90* CCL
Main Studs: 7/16 ARP
Main Bearings: Clevite 77
CRANK: Eagle 4340 Forged
Internal Balanced
FLEXPLATE: Internal Balanced
BALANCER: BDS Crank Hub
RODS: Crower 5.7 Stroker Sportsman
ROD BOLTS: Crower
ROD BEARING: Clevite Std
PISTONS: Arias Blower Pistons
Dome CC: -28.73
PINS: Arias
Locks: Arias
RINGS: Sealed Power
Top Gap: .024
Second : .024
CAM: Isky Hyd Grind BDS-4200 HYD
Lobe Center: 110
Valve Lift: .465/.485
Advertised Duration: 270/280
Duration @ 50*: 221/232
HEADS: World Sportsman II
Combustion: 72cc
Intake Volume: 200cc
Manley Valves: 2.02/1.6
Push Rod: Sealed Power
3/8 Rocker Studs
Crane Roller Rockers 1:5
EXHAUST: Hooker
VALVE COVERS: Billet Specialties
TIMING CHAIN: Cloyes Double Roller
TIMING CHAIN COVER: Cloyes Quick Button
OIL PAN: Moroso 7 qt
OIL PUMP: Melling Hi-Volume
OIL PICKUP: Moroso Hi-Volume
INDUCTION: Weiand 671 blower
BDS 8 nozzle efi top hat
ECM: FAST
IGNITION: MSD
Joe
1975 C10 blown 383
HAULIN IT
October 14, 2010, 08:03:28 pm »
455 Olds:
Standard bore - stock cast pistons (10.1 compression), stock rods & crankshaft
Hyd. flat tappet cam - 238/246 dur. @.050 540/558 lift
Home ported "E" code heads with stainless valves & Harland Sharpe roller rockers
Torker intake
Home modded Q-jet carb
Recurved HEI distributor
1 3/4" Headman headers & 3" pipes with bullet mufflers
Best E.T. - 11.82 @ 112mph.
October 14, 2010, 08:16:37 pm »
Too many to list! lol
ccz145a
October 15, 2010, 07:50:08 am »
454 +0.030
9:1 Dome Pistons
781 Large Oval-Port heads
Hydraulic Flat Tappet, Advertised Duration 218 int./228 exh. @0.050, Lift .500/.500
Iron Intake w/Quadrajet
Last Edit: October 17, 2010, 10:20:45 pm by Captkaos
October 17, 2010, 10:21:15 pm »
Chip, I had to delete your pic. Something hosed this thread.
Performance
Engine Builds!!!
