Author Topic: NV4500 swap  (Read 4755 times)
Offline 75Chev
NV4500 swap
« on: October 12, 2010, 06:48:50 pm »
Hey everyone. I'm swapping out the SM465 in my '75 chevy for a NV4500 5 speed out of an '88 chevy 1 ton pickup that had a 454.  Will the spline and size of the input shaft of the NV4500 be the same? Also, what about the bell housing? is it interchangeable?
Offline 1980c10
Re: NV4500 swap
« Reply #1 on: October 12, 2010, 07:08:40 pm »
not too sure about most of that but you will need to modify the crossmember and most likely convert to a hydraulic clutch assembly. good luck and keep us posted of your progress
Offline 75Chev
Re: NV4500 swap
« Reply #2 on: October 12, 2010, 07:25:43 pm »
I was told the NV4500 could be used with a manual clutch assembly?
Re: NV4500 swap
« Reply #3 on: October 12, 2010, 08:04:43 pm »
I know the nv3500 93 and older you can swap bell housings with the 465. Here is some prices on a adapter plate if you wana keep the 465bell housing http://www.nv4500.com/product_info.php/cPath/3144/products_id/24275
