Author Topic: stabalizer bar/ sway bar  (Read 5984 times)
Offline 85K10
« on: October 12, 2010, 11:47:11 pm »
Is anyone using the Swaybar Correction/Disconnect Kit from ORD? If so, how do you like it?
Does the 2" lift of the bar help on the road?
 Patrick
« Last Edit: October 12, 2010, 11:52:24 pm by 85K10 »
Offline N2TRUX
Re: stabalizer bar/ sway bar
« Reply #1 on: October 19, 2010, 11:44:45 pm »
Anyone?
« Reply #2 on: October 23, 2010, 11:10:14 am »
Don't have a driving 4x4 right now and it is stock.  I haven't used one though.
Offline 85K10
« Reply #3 on: October 23, 2010, 04:55:40 pm »
OK, a little update: got the weld on frame repair kit and it was actually thicker than I thought it would be,about 1/8". Went on great. Also did the swaybay disconnect kit. I have 4" lift springs on front and I think it let's them flex just a little more. Slightly smoother on the road,although don't get me wrong,the springs are still pretty stiff. If you have a lift, I think this kit is worth the bucks.
 Patrick
« Reply #4 on: October 23, 2010, 07:24:32 pm »
Do you have pics of your installs?
Do you wheel a lot to need the disconnect kit? Just curious. I opted for the sway bar drop brackets.
Offline 85K10
« Reply #5 on: October 23, 2010, 10:11:16 pm »
No pics, try to get some soon. beastie,if you look at my intro post you will see where I stand with this truck. Have not got to try it on the trail yet. As far as the disconnect kit,I liked the idea of the way it works and I was already ordering the frame kit,so I went with it.The way you went may have got me the same results as the kit I got,just can't disconnect it.If I ever get to the trails I will try the disconnect feature and report back.
 Patrick
