Author Topic: MICKEY THOMPSON ON RALLEY?  (Read 27966 times)
Offline 82BlazerMan
    • Blazer pics
Re: MICKEY THOMPSON ON RALLEY?
« Reply #15 on: October 31, 2010, 10:32:03 pm »
I had Hoosier qucktimes in 325/50R15's and they were almost an inch wider than the same size BFG drag radials.
Did you run tubes with those Hoosiers?  Summit says their required.
1982 Blazer 2WD
305ci
700R4
Offline KILLERC10
« Reply #16 on: January 04, 2011, 10:35:12 pm »
So a 315-60 might fit a 15x8 ralley?
« Reply #17 on: January 05, 2011, 10:39:00 pm »
     All that back and forth and KILLERC10 still didn't get his question answered..... ::)
« Reply #18 on: January 06, 2011, 02:08:43 pm »
Yes, see Lorne's first post.
You can get away with the 315/60 15 or the 325/50 15, both are 11" wide tread. Mickey Thompson doesn't reccomend it, but I ran the 325/50's on an 8" wheel for a couple years. They looked a bit "balloony", but wore ok. Lorne
Offline 82BlazerMan
    • Blazer pics
« Reply #19 on: July 13, 2011, 12:21:22 pm »
Hey I'm thinking about getting some Hoosier 325/50/R15's but they say they need tubes?  Since I'll be running on the street and I won't really be hot rodding it, could'nt I mount them without the tubes?
1982 Blazer 2WD
305ci
700R4
« Reply #20 on: July 14, 2011, 02:35:48 am »
might need the tubes because the tires are more porous than other tires? not a tire expert.
Offline chevymanrob
« Reply #21 on: July 17, 2011, 05:31:39 pm »
if they suggest tubes and you plan on NOT having to air the tires up every day you drive it then buy tubes. my old ET Streets would bleed air thru the sidewalls. one was worse than the other. think 15-20 ponds PER DAY!!! funny, after i bought a smaller set with tubes they never lost a pound again :).
moral of the story, buy tubes and call it done or buy radials.
ex G-body drag fan. best was 11.86 on a 93 octane SBC street car.
Offline 82BlazerMan
    • Blazer pics
« Reply #22 on: September 14, 2011, 01:04:16 pm »
These are 29x12.5 R15 Mickey Thompson Sportsman Pro's.  They have about 3/8" clearance each side.  Perfect!
1982 Blazer 2WD
305ci
700R4
Offline 73k5
« Reply #23 on: October 06, 2011, 10:34:42 am »
Im not running tubes in my 315/60/15 Hoosier D/R on my turbo stang and they never leak down...
« Last Edit: October 06, 2011, 10:36:14 am by 73k5 »
