Body, Glass & Paint
Crew Cab cab swap Question
Topic: Crew Cab cab swap Question (Read 4899 times)
Pullin81
MY86
October 19, 2010, 08:59:13 am »
well i got a 85 crew cab 4x4 the other day n slowly finding rust that i dont want to deal with. i also have a 75 crew cab 2wd. Is the only difference the rubber mounts on the cabs?
86 gmc short box...454/th400
81 gmc crew cab dually bagged 5.9 cummins/nv4500
1HI4x4
V30 Crew now a shortbed.....
Re: Crew Cab cab swap Question
October 19, 2010, 12:35:50 pm »
Tranny Hump should be different
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
Blazin
Blazin new trails!
October 20, 2010, 10:32:10 pm »
The cab mount bushings are different. The 2 wheel drive floor center hump is not the same. You will need to remove it and put the hump out of the 4x4 in to clear the t case. The hood hinges are in the cowl on an 85.
Body, Glass & Paint
