Author Topic: Do you retorque your radiator hose clamps?  (Read 7846 times)
Offline Brady
« on: October 19, 2010, 09:20:27 pm »
I replaced the radiator about a week ago and replaced the hoses at the same time.  I had been driving it all that week and I thought everything was ok and had just parked in my garage when I heard my coolant spraying out on the floor.  I know I had tightened that clamp when I installed it; it was a screw type clamp that is commonly sold in auto parts stores.  I had this happen a few years ago when I replaced the hoses, but that time I caught it when it was just a drip and retightened the clamps.  When I took those hoses off this time, I could see that the clamps had squeezed the hoses way down and I wondered if there was any danger of causing a failure by overtightening.
Do you guys go back and retighten the hose clamps after a few days?  Is there a danger of overtightening them?
TIA,
Brady
Offline Canadian 4X4
Re: Do you retorque your radiator hose clamps?
« Reply #1 on: October 19, 2010, 09:26:59 pm »
Yes you can over torque the worm type clamps
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: October 19, 2010, 09:34:54 pm »
in my nearly 3 decades of using those clamps, I never go back to retighten them, and have never had any problem.  And as mentioned, you can overtighten them and cut the rubber.
Offline N2TRUX
« Reply #3 on: October 19, 2010, 11:34:27 pm »
I double check them if I installed a new hose. The hose is prone to compress a bit after a few heat cycles, and can leave a bit of slack in the clamp. Maybe its just me, but I would rather be cautious than have sticky antifreeze all over my motor.
Offline jaredts
« Reply #4 on: October 20, 2010, 05:21:23 am »
I bet you got a cheap hose clamp.  I've never had a problem with these, but I've had a rash of clamps that stripped out before they were tight enough or came loose just in the past couple of years.  I think the ones I had a problem with were from Autozone, so I've bought my last few from NAPA.
Offline Brady
« Reply #5 on: October 21, 2010, 08:01:29 pm »
Thanks for the responses.  This is the second time I have had this happen, but before it was just a leak; this time it was a torrent.  I think I will be rechecking them after this.  The one that is hard to get to, I doubled up on the clamps.  It could be that with rough clamps I wasn't getting them as tight as I thought.
« Reply #6 on: October 21, 2010, 08:20:50 pm »
Do you have the right hose? If you're squeezing the hose down to make it fit you may need a different hose. Different radiators have different diameter outlets.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #7 on: October 21, 2010, 09:15:58 pm »
I've never re-torqued any of them, though I have ruined  a few.  i tighten them up until i think they are tight enough and if they break they were inferior to begin with.  ;D
Offline Brady
« Reply #8 on: October 21, 2010, 11:49:07 pm »
Yes, it was the right hose.  It took a little bit of twisting and effort to get it on.
