Author Topic: NP 205 and ATF  (Read 5075 times)
Offline snibook7537
  • Vince Ziolkowski
NP 205 and ATF
« on: October 23, 2010, 10:33:35 pm »
I was just wondering, I did a quick search on here and didn't find anything about it. So here goes I bought the truck with the assumption it needed a clutch due to a messed up T/O bearing. Just took the trans and t case out today and found out it was a messed up t/o and it chew up the front input bearing off the trans, (just finished ordering one off of novak). In the trans I will be putting 50w engine oil (novak says it is okay I didn't think it was that good either but I've herd of doing that from my uncle too. http://www.novak-adapt.com/knowledge/sm465.htm). I did drain the t case and it had ATF in it. My step dad said we should just put atf back in it, but I am a little hesitant to do that, will it be okay with atf or  is it messed up now. By the way it is an 87 v3500 with an sm465 and a tbi 350. Also i put a Zoom clutch in it, anybody every use one, if so how do you like it, it is the Zoom Multi-Friction Clutch Set. I am really excited about this truck will be my second truck and my first 4x4, just don't want to be finding a 205 to put back in it.
So what fluid should i put in the transfer case.
Thank You Much
vince
1984 Fiero se pwr windows Holley TBi, cam, 86 5spd
1987 GMC V3500 350 TBi 4spd 205 t-case
Shoulda never sold:
1976 c-10 beater 250-6 4spd no pwr steering, brakes. Recycling truck
Re: NP 205 and ATF
« Reply #1 on: October 23, 2010, 10:48:51 pm »
It calls for ATF DEXRON in the 205 transfer case.
The transmission calls for 80W90
Offline snibook7537
  • Vince Ziolkowski
Re: NP 205 and ATF
« Reply #2 on: October 24, 2010, 09:52:22 am »
Thanks Vile
Shoulda never sold:
