Author Topic: windsheild wiper motor  (Read 14466 times)
Offline Buddy
« on: October 24, 2010, 12:15:39 pm »
Ok here we go, I never tried the wipers before I did my rebuild so I have no clue if they worked before. I cant seem to get them to work, not sure if it is my switch or my motor or the wiring. I tried to figure this out from the wiring diagram but I am lost. I have two plugs that come from the fire wall, one plug up top and one down bottom of the motor. Can anyone tell me what each are for? I grab the test light and with the key on I seem to have power to each plug. When I trun the switch to low or high or whatever I cant seem to get any of the other terminals to light up on the test light. I have no clue what is wrong. anyhelp or even a starting place would be a big help. Also do the swirch ever go bad in these things? Truck is an85 with the switch on the column.
Re: windsheild wiper motor
« Reply #1 on: October 24, 2010, 02:05:32 pm »
what year is your truck? check the tech section for the wiring diagrams.
Offline Buddy
« Reply #2 on: October 24, 2010, 06:06:37 pm »
anybody????
« Reply #3 on: October 24, 2010, 06:46:31 pm »
Randomly probing wires with a test light won't tell you anything.
WIPERS INOPERATIVE
Turn ignition on and check for battery voltage at wiper motor terminal 2, Fig. 5, using a test lamp.
If lamp fails to light, proceed as follows:
Check wiper system fuse and replace if needed.
If fuse blows again, disconnect electrical connector to motor and replace fuse.
If fuse does not blow with harness disconnected, replace wiper motor.
If fuses continue to blow with harness disconnected, or if fuse was satisfactory in step ``a,'' repair feed circuit to wiper motor.
If lamp lights in step 1, check for battery voltage at motor terminal 1.
If lamp fails to light, check terminal board connections and repair as needed. If connections are satisfactory, motor is defective.
Place wiper switch in low position, disconnect electrical connector to gear box relay and connect test lamp between terminals 1 and 2 in connector.
If lamp fails to light, check continuity of wiring between motor and switch, switch continuity and ground, and repair as needed.
If lamp lights in step 5, place wiper switch in high position, disconnect electrical connector to pulse timer and connect test lamp between terminal 6 and timer connector and terminal 2 in gearbox relay connector.
If lamp fails to light, check continuity of wiring between motor and switch, switch continuity, and repair as needed.
If lamp lights in step 7, motor is defective.
« Reply #4 on: October 25, 2010, 11:31:19 pm »
So, my help wasnt helpful?
