Author Topic: priority start  (Read 9924 times)
Offline wrangler
  • 85 C-10 350 carb 2wd recently added air
priority start
« on: October 25, 2010, 02:56:28 pm »
just curious what would happen if a couple of ground straps were gone?  Woud this be enough for a new battery to go dead after sitting for about three weeks?  Could this be caused by bad battery cables?  I had my truck to an electrical shop and they told me that I had no draw on the battery when the engine is off.  I'm lost!  frustrating...  ???
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: ground straps
« Reply #1 on: October 25, 2010, 03:58:43 pm »
Having a minimal ground connection to the engine/frame from the battery has nothing to do with the battery going down prematurely.
However, if the negative ground is not enough for the starter to turn the engine over, it will seem like the battery is dead---in actuality, you're not getting a complete efficient circuit.   But, it won't drain the battery that way when it sits.
You also have to ensure your alternator has enough of a ground connection to charge the battery once the engine is on
Offline wrangler
priority start
« Reply #2 on: April 20, 2011, 06:45:46 pm »
My truck sits sometimes for a couple of weeks at a time and most times when I try to start it, the battery is dead.  Couldn't find the problem so I bought a Priority start, that hooks to the battery and auto disconnects it when it hits 11.7 volts, saving enough power to start the truck.  My question is about my stereo, can I run my yellow wire directly to my battery so I can keep memory to my clock and presets, and if so what guage wire and fuse should I use.  I don't see why this wouldn't work, but I'm not an expert by any means.
Re: priority start
« Reply #3 on: April 20, 2011, 07:01:54 pm »
Why not just fix it? Sounds like you have a parasitic draw. Do you have a digital meter or at the very least a test light?
Offline wrangler
Re: priority start
« Reply #4 on: April 20, 2011, 07:10:37 pm »
had it to two shops last summer and neither could find any draw, but the battery still went dead until I finally had to replace it.  I don't want to ruin another battery so I went this route.  I know its not a fix, but I'm hoping I'll be able to start it when I want to drive it.  My only concern now is the memory in the stereo, if I have to set the clock every time the battery drops below 11.7 volts, not cool!
Re: priority start
« Reply #5 on: April 20, 2011, 07:15:43 pm »
So again,
Why not just fix it? Do you have a meter or at least a test light? Checking for a parasitic draw on one of these trucks is about as easy as it gets.
Offline wrangler
Re: priority start
« Reply #6 on: April 20, 2011, 07:19:29 pm »
how would I go about doing it, would love nothing more than to fix it?  have both.
« Last Edit: April 20, 2011, 07:22:33 pm by wrangler »
Offline wrangler
Re: ground straps
« Reply #7 on: April 20, 2011, 08:18:12 pm »
the battery cables on the truck are original and 26 years old.  Could that alone cause a seemingly dead battery.  When I put the charger on, it only takes a minute to start it up.
Re: ground straps
« Reply #8 on: April 20, 2011, 08:19:09 pm »
OK - let's keep one thread for the same problem.
Re: priority start
« Reply #9 on: April 20, 2011, 08:23:04 pm »
Get your test light out. Turn everything off close the doors and make sure nothing is on. Disconnect the negative battery cable. Connect a test light between the negative cable and the negative post.
Is the light on? If so how bright?
Report
Offline wrangler
Re: priority start
« Reply #10 on: April 20, 2011, 08:28:28 pm »
Thanks, will report back tomorrow night.
Offline FatgentryC25
Re: priority start
« Reply #11 on: April 21, 2011, 12:22:25 am »
My friend and I are in the same boat. We hooked up the meter on his 73 model, which is a wiring nightmare, swapped the junction box on the firewall and traced it to the alt. We thought it was the voltage regulator. The alt wasn't charging properly anyways, so he got a new one. As long as he unplugs his alt., the battery is fine. However if he leaves it pluged in while in class, at work or overnight, his battery dies. We dont get to work on it much due to time schedules. Good luck wrangler, keep us posted!
'75 GMC Sierra C25
 Bored 350, Comp cam, Accel ignition, stage III clutch, sm465, 14ff on 16.5x33
'78 Chevy Custom10
 Targetmaster 350/th350/np203, 3.07's, on 38.5's
Offline wrangler
Re: priority start
« Reply #12 on: April 22, 2011, 12:16:43 pm »
Just did the test with the light.  When I first put the light between the negative cable and the battery, it came on bright and then faded out.  Could only get it to come back on by unhooking both sides of the tester and hooking it back up, it doesn't stay on.
Offline 1979C20
  • Kyle Taulton.
Re: priority start
« Reply #13 on: April 22, 2011, 01:08:51 pm »
What do you have for your stereo system. If you have a capacitor(not likely but if) then that could be the culprit.
Offline wrangler
Re: priority start
« Reply #14 on: April 22, 2011, 03:23:09 pm »
I have 2 amps hooked up, taking power directly from the battery.  They only come on when the stereo comes on, or so I think.
