Author Topic: Custom Cluster in the works  (Read 52150 times)
Offline modular93fox
« on: October 26, 2010, 10:51:04 pm »
About 2 years ago I seen a wicked cool hybrid looking cluster. It was in a cummins conversion suburban, (original photos not hosted anymore, and my photos I had taken are misplaced) but it was so wicked good looking, I went out and picked up a Dodge Ram 1500 instrument cluster. The gauges alre a perfect match for the factory bezel, the small gauges are a 100% perfect, the 6k tack and 120mph speedo are like 1% too small due to 1 notch in one spot on each of the gauges. I never got hot and heavy about the project but its always in the back of my mind. Well about a month ago I jumpstarted the project by figuring out exactly how to mount these gauges.
Seriously after about 2 hours of brain storming I got the perfect solution.
 and
the MPH and Speedo are not shown becuase I need to tweak it just a bit.
clint
1987 5.3 4l60e Silverado - daily driver with A/C,P/W,P/L,TILT, HID projectors & 13.8" Rear Disc Brakes
A poor man buy's it twice
Re: Custom Cluster in the works
« Reply #1 on: October 26, 2010, 11:02:02 pm »
by design its a 3pc carrier, the back, the block spacer and the front trim. Screw the gauge and make the electrical contacts to the back plate and screw in the spacer followed by the gauge face trim ring. With the cluster assembled the idea would be to mark the center of the gauge needle on the clear lense of the cluster for reference. Disassemble the cluster and cut the lip of the black plastic (not available online :( ) trim that surrounds the gauges. Now that the black trim is nice and flat (no lip) & with the gauges in its new carrier, place it on the back of the black trim (with the clear lense fitted on the front side) and align it so that the center of the gauges is where the center of the marks you made on the plastic clear lense. Make a pilot hole in the middle use a screw to hold them together. Once fitment is good to go, I need to see what epoxy glue would be best to glue the 2 together. Just to ensure they are stuck together real good :). Sounds good to me anyway.
clint
« Reply #2 on: October 27, 2010, 11:42:14 am »
Got a quote using the SLS method. its not to bad, low 300 for all 3. Im gonna sleep on how many I am going to order.
clint
Offline eventhorizon66
« Reply #3 on: October 27, 2010, 01:52:57 pm »
Is this the Suburban you're talking about?
http://www.devilscastle.net/cummins2006-dec.htm
'85 C10 SWB 350 700R4 TKO600
« Reply #4 on: October 27, 2010, 05:57:49 pm »
yep. I went through my external and found the photo of when I put all of the gauges in the cluster...
clint
« Reply #5 on: October 27, 2010, 06:02:02 pm »
Great concept but not very stylish gauges.
« Reply #6 on: October 27, 2010, 10:24:48 pm »
true, but thats what I was looking for.. Im not into the white faced flamed look that aftermarket might offer... but there might be kits offered to change the face or needles to something more exotic. Ive seen needle kits for the NNBS silverdao's... neat but not for me. For function, this setup is great for me, it gets rid of the tach on the dash and gets the sleek look of through the dial lighting with the more MPH on the dial.... my 5.3 engine doesnt like the 85mph speedo
clint
« Reply #7 on: October 27, 2010, 10:42:06 pm »
Don't get me wrong, I'm not knocking it at all! They still look cool
« Reply #8 on: October 27, 2010, 11:30:30 pm »
I wish someone made a good aftermarket replacement tach with the built in gas gauge like the newer 85 on up I have seen.  I would like to find the GM part # on it and see if any exist any more.
Offline topp
« Reply #9 on: October 28, 2010, 08:24:31 am »
clint
I like it....
What gauges are they?
'90 Suburban TBI 350
« Reply #10 on: October 28, 2010, 05:57:21 pm »
came out of a dodoge ram 1500 96-98 gas v8
« Reply #11 on: October 28, 2010, 10:27:59 pm »
Contact this guy that sells the factory tachs
http://cgi.ebay.com/ebaymotors/1973-1986-Chevrolet-Chevy-truck-tachometer-gauge-set-_W0QQcmdZViewItemQQitemZ150481634140QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
« Reply #12 on: October 28, 2010, 10:54:58 pm »
his tach looks like the fuel gauge with some sort of tack fixed to it and a overlay. none the less, its a lot less work. When I pull the trigger I will have invested about 50$ more than that guy is selling his kit for. 270 for the adapter carrier and 50 bucks for the cluster. Once I get my project finished I might take apart my autogauge tach and see how to fit it to the gas gauge... but thats another project another time.
« Reply #13 on: October 29, 2010, 06:50:13 am »
The one I am looking for has the gas gauge built in the tach.  I have seen one only on eBay.
« Reply #14 on: October 30, 2010, 12:25:08 am »
Contact that guy, last I knew he sold the diesel, heavy truck and 10-30 tach's as well as complete assmenliees. 99.9% of the used ones you'll find on eBay will not be functional.
