Author Topic: EGR valve removal  (Read 3653 times)
Offline firestop52
EGR valve removal
« on: October 30, 2010, 08:42:05 pm »
I have a 1984 K10, 305 700r4.
Can I do away with my EGR valve and related vacuum lines and switch.  Does this have anything to do with the torque converter lock up system? I would like to do away with some of these vacuum lines but I am not sure about this switch mounted just above the EGR valve. It has 2 vacuum lines on one side and wires plugged into the other side. Thanks for any help.
Re: EGR valve removal
« Reply #1 on: October 30, 2010, 09:57:12 pm »
It depends on the emissions laws. If it's stock and you just want to remove it, you're not doing yourself any favors.
Offline firestop52
« Reply #2 on: October 30, 2010, 10:59:25 pm »
 Will this make no difference in how it runs? Better or worse?
« Reply #3 on: October 30, 2010, 11:29:57 pm »
It will basically pollute more and may cause pinging. Need more info on your set up and your goal to offer better advice. Again if it's just a stock set up removing it doesn't make much sense especially if you ever go to sell it to someone who has emissions laws.
