Author Topic: 76 vette engine, seems weak but.....  (Read 12307 times)
Offline project85
« on: October 31, 2010, 06:45:08 am »
my truck is an 85 c-10 2wd. i don't know what gears are in the pumpkin and it has a 3 speed on the floor so some of the doggieness could be high gears but, it has a 76 vette 350 engine, the L 48. which from what i've found it has 190hp from the factory. it has original exhaust manifolds that go into a single muffler. the motor is tight and runs good just seems doggie. i wanted to know what you guys think. will it be a big difference with a pair of headers and dual pipes with a set of low back pressure mufflers. it also has a holley dual feed double pumper on it which seems like way too much carb for a weak motor like this. i don't know if an edelbrock 600 will help out any.
thanks
1985 C-10 Deluxe Step Side
Offline frogman68
Re: 76 vette engine, seems weak but.....
« Reply #1 on: October 31, 2010, 06:53:59 am »
not to be rude did you put the vette engine in or did the guy that you bought the truck tell you it was a vette engine ?
Drivers side block behind the head (by the brake booster) is the casting number might need a inspection mirror and carb cleaner (to clear the area) get those numbers
That will tell alot in itself
« Reply #2 on: October 31, 2010, 06:59:35 am »
Tune it up, play with the timing. That trans isn't doing you any favors and find out what your final drive ratio is.
Offline project85
« Reply #3 on: October 31, 2010, 07:06:04 am »
When I first called the guy about the truck he said it had a 73vette motor. When I went and checked it out someone had written 76 vette L-48. I havnt pulled the numbers off yet to confirm what it is. One of my projects for today. Also on the list, new cap, plugs, wires, pads and maybe rotors.
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #4 on: October 31, 2010, 08:04:46 am »
The 76 L-48 Vette engines were some of the weakest ones ever put in a Vette. Not to burst your bubble but they weren't very strong even in the Vette. :(
Offline velojym
« Reply #5 on: October 31, 2010, 08:55:05 am »
Let 'er breathe, too. I'm guessing that exhaust is pretty restrictive.
Offline eventhorizon66
« Reply #6 on: October 31, 2010, 12:40:02 pm »
This is what I was gonna say.  But it is a 350, so it has potential.
'85 C10 SWB 350 700R4 TKO600
Offline bobcooter
« Reply #7 on: October 31, 2010, 02:34:41 pm »
Oh for sure. He's got a good starting place.
Offline xCaliC10x
  • BMW Witch Doctor
« Reply #8 on: October 31, 2010, 03:24:58 pm »
Correct me if I am wrong, but wasn't the "Big Ten" with a 454 the fastest thing you could get out of GM in the mid 70's due to emissions? The Vette was listed as a passenger car and subject to stricter standards where the "Big Ten" was listed as a "heavy duty" commercial truck and got out of cats and stuff for a few years.
The motors were pretty choked down, but that can all be fixed.
'80 C10 short bed 350/SM465, Edelbrock carb/manifold/Elgin cam/custom headers/magnaflow, flip kit, spindles/springs.
'09 328i coupe sport package. Magnaflow exhaust.
'11 335d diesel 425ftlbs, 27-30MPG city, 40-44MPG hwy.
Offline project85
« Reply #9 on: October 31, 2010, 03:35:02 pm »
for now i'm gonna probably put a set of headers and dual exhuast, tune up and see if it helps alittle. i know from what i read online 76 was like the worst year ever for vette motors. i have a target motor in the garage that i will build up over the winter. i gotta try to find a set of heads and find out what the gear ratio is.
Offline 70 beater
« Reply #10 on: November 01, 2010, 05:57:01 pm »
From something I read years ago, has me thinking it was pretty much the same engine in the p/u's and vettes. I had to have been reading something for or about my truck, a '76.
Offline project85
« Reply #11 on: November 01, 2010, 07:59:32 pm »
Was your 76 truck real doggie or is it pretty strong. Or did you do some stuff to it to get it strong??? If I could get some idea of what might have worked for you I can use it for a blue print for me.
Thanks
« Reply #12 on: November 05, 2010, 07:27:45 am »
GM didn't offer a "strong" SBC in the mid-70's.  That was a pretty dark period for performance.
If you are interested in making your 350 strong, here are some of the best guides for doing so:
http://www.amazon.com/David-Vizards-Build-Horsepower-Design/dp/1934709174/ref=sr_1_3?ie=UTF8&qid=1288959992&sr=8-3
http://www.amazon.com/Build-Chevy-Small-Blocks-Budget-Performance/dp/1932494847/ref=sr_1_1?ie=UTF8&qid=1288959992&sr=8-1
Offline bobcooter
« Reply #13 on: November 05, 2010, 10:23:57 am »
A K&N air filter with an open element air cleaner would help.
« Reply #14 on: November 08, 2010, 08:01:35 pm »
In 1978 and 1979, yeah, that is true.
