Author Topic: TH350 Tailshaft Length  (Read 9781 times)
Offline adams18
« on: November 07, 2010, 04:27:38 pm »
I have a TH350 with an NP208 behind it out of a 1978 1/2 ton. I was wondering if there is a standard tailshaft lenth for the 4x4 TH350's or if they differ like the 2wd versions do. I know there are 6,9, and 12 inch tailshafts, but is there an extra short tailshaft that was used for the 4x4s since they dont use a tailshaft housing? thanks
Re: TH350 Tailshaft Length
« Reply #1 on: November 07, 2010, 05:38:45 pm »
There is no tailshaft for the 4x4 trans
« Reply #2 on: November 07, 2010, 05:41:23 pm »
Output shaft?
Offline adams18
« Reply #3 on: November 07, 2010, 05:45:09 pm »
Yeah.. my bad. Output shaft.
« Reply #4 on: November 07, 2010, 06:06:38 pm »
I think it depends on the transfer case its attached ie. The 205 mated to the th350 will be shorter due to the smaller adapter plate than a th350 mated to a 203
Offline Russ130
« Reply #5 on: November 12, 2010, 05:50:29 pm »
Pretty sure there is only one output shaft length for 4x4 applications
