Author Topic: Brake lights stay on  (Read 7063 times)
Offline ITSANSS
« on: November 07, 2010, 04:43:32 pm »
1985 Chevrolet Silverado
355c.i. (just a stock remanufactured engine)
700R4
Just did an engine swap and now that the battery is back in, I noticed the brake lights stay on.  I jerked on the pedal, did nothing; stomped on it, nothing; wiggled on it, nothing.  They won't go off.  I've heard/seen worn out brake light switches, but this one was fine before engine swap and even messing with the pedal doesn't do anything.
I had the brake booster out when I painted the engine bay.  Could I have done something to the wires getting that out?  I have to pull the fuse to make them go off.
What should I look for?
Thanks
PS  The blinkers, back-up lights, head lights, etc. work fine still.
« Last Edit: November 07, 2010, 04:47:35 pm by ITSANSS »
Offline Dr_Snooz
Re: Brake lights stay on
« Reply #1 on: November 07, 2010, 04:52:38 pm »
Check the adjustment of the little switch at the pedal. It might just need adjusting.
My brake lights were staying on. It ended up being my trailer brake box. The switch was hanging up.
« Reply #2 on: November 07, 2010, 05:03:31 pm »
Check the brake light switch.
Offline ITSANSS
« Reply #3 on: November 07, 2010, 05:24:06 pm »
Where is the switch exactly?  I looked around up there, but didn't see anything obvious (to me).  Of course, there is barely any room to get around and even see up there anyhow.
Got a picture, perhaps?
Thanks
« Reply #4 on: November 07, 2010, 05:25:11 pm »
You can't miss it. Look at the pedal arm and it actually contacts the switch when it returns to the up position.
Offline ITSANSS
« Reply #5 on: November 08, 2010, 08:28:33 pm »
lol  Figured it out.  There's a metal bracket that mounts onto the brake pedal arm.  I had taken it off when removing the brake booster.  I couldn't see the brake light switches (there are two, not sure what other one is for) because of the HVAC duct work.  Jerked out a piece of ducting and, voila, switches.  Then it all came rushing back to me.  Oh, yeah...that little metal bracket that had two shiny spots on the back as if somethin' were rubbin' on it.   ::)
They now work as designed.   :)
