Author Topic: Eliminating smog lines, canisters  (Read 30810 times)
Offline 1979C20
  • Kyle Taulton.
« on: November 13, 2010, 12:39:24 pm »
1979 C20, rebuilt 350 stock qjet 4br rochester. I have the truck registered in globe and dont have to do emissions. The truck is from california and has 2 smog canisters and the a.i.r. pump. I removed the exhaust manifold and put headers on so i looped the smog pump, going to remove it. But, when I remove the pump I want to remove all of the other smog crap. The 2 canisters and unnecessary vacuum lines. I need to know what I can remove and not affect functionality.
Offline topp
Re: Eliminating smog lines, canisters
« Reply #1 on: November 13, 2010, 12:43:18 pm »
Technically, removing ANY of that is a FEDERAL offense, and if you get spot checked when driving anywhere, you go to jail for long time....
The AIR pump helps your truck warm up faster and lowers emissions on cold starts.
The Canister keeps raw gasoline vapors from entering the atmosphere and keeps your vehicle from smelling like it has a gas leak...
Dunno why you'd remove items that make your engine run better and save your gas from evaporating away....
'90 Suburban TBI 350
Offline 1979C20
  • Kyle Taulton.
« Reply #2 on: November 13, 2010, 12:49:18 pm »
Emissions is not required in Globe, AZ and spot checks, etc are not done. I ran my truck with no mufflers for like 3 months and nobody said anything, even cops, The AIR pump is useless at the moment considering the fact I don't have emissions exhaust manifold. And the vacuum canisters are just in the way and causing irritating vacuum leaks.
Offline topp
« Reply #3 on: November 13, 2010, 12:56:05 pm »
Per Federal law, tampering or removing ANY Emissions equipment mandated for your model year.  Federal law OVERRIDES state law.
Yes, you can drive your vehicle, and yes you have no emission tests...but you still have to pass a VISUAL inspection.
Also, removing your Cannister can cause wonderful issues like vapor lock....
Offline 1979C20
  • Kyle Taulton.
« Reply #4 on: November 13, 2010, 01:00:32 pm »
I dont have to do any inspection. All I had to do was go to the DMV and register it. No inspection or testing required. And vapor lock is caused by the fuel getting hot and boiling before it reaches the carb. Not from lack of vacuum canisters. If I was going to get vapor lock, it would have happened already. But, my fuel line is not against any hot objects. So, I dont have to worry about vapor lock.
« Reply #5 on: November 13, 2010, 01:14:18 pm »
I seriously doubt he is going to get arrested and go to jail for a long time because he took off his a.i.r. pump and charcoal cannister. Who would he have to pass a visual inspection for? A cop?  ???
I would too ditch the a.i.r. pump system and as far as the cannister I agree I would leave it unless this is a hot rod that you are neatening up the engine compartment for show reasons. You should document and save where everything goes in case you ever sell it to someone who is going to have to reg it in CA
Offline 1979C20
  • Kyle Taulton.
« Reply #6 on: November 13, 2010, 01:17:47 pm »
Well, I honestly don't need the vacuum stuff, Its taking up space. And, like I said, I've had to fix a bunch of vacuum leaks because of them already. So, I'm trying to save myself the money of buying new vacuum lines.
Offline topp
« Reply #7 on: November 13, 2010, 02:18:40 pm »
Lets see...He takes it off...Next year they roll back emissions on his vehicle, he doesn't have the emissions- They impound his vehicle....or he gets a roadside inspection, They charge him, cite him and impound the vehicle.
Uncle sam has gotten very tricky with emissions. California rolled back the year after rolling forward, NC has a county by county emission..
Look at these
http://www.aircarecolorado.com/rapidscreen/index.html
http://www.smogtips.com/remote_sensing.cfm
http://cbs4denver.com/green/Mobile.units.start.2.1722811.html
And as for what can happen getting caught- http://autos.yahoo.com/maintain/repairqa/exhaust_muffler/ques081_0.html?AID=10665418&PID=3925582
Offline 1979C20
  • Kyle Taulton.
« Reply #8 on: November 13, 2010, 02:30:25 pm »
What do you mean "roll back emissions"? Globe, AZ does not require emissions testing on inspection for ANY vehicle of ANY year, make, model, type.
« Reply #9 on: November 13, 2010, 02:49:05 pm »
The most he should be is a inspection ticket well in MD at least saying you have to pass within 30 days maybe a fine. I'm running straight pipes and with a lift way above state limits and go threw check points and pass cops with no problem. Now lets say I blow by a cop with my open pipes then they will go after me
Offline topp
« Reply #10 on: November 13, 2010, 02:51:55 pm »
California, a few years ago made it so '76 and newer only had to have emissions...Then, a year or two later, they made it so '74 or '75 and newer.  All  those people who removed their emissions stuff then were screwed...
You may have no emissions now, but next year, or the year after, they may roll it back...Then you are screwed....
I'm not telling you not to remove stuff, but if you do, you can end up in a world of pain with a vehicle that gets scraped.
Offline Grim 82
« Reply #11 on: November 13, 2010, 03:47:59 pm »
According to that link he's already screwed because he put the headers on, so he might as well ditch the rest of it. It's surprising to read how carried away they get with it as far as recurving your advance or "tampering" with idle mixture. They would have us all driving a Prius if they could.
Offline topp
« Reply #12 on: November 13, 2010, 03:51:53 pm »
unless he buys CARB headers ( I did)..
They have now made it illegal to add a2nd cat if you went to true duels) if the vehicle only came with one from the factory...
And YES, they are trying to make us all drive prius
Offline 1979C20
  • Kyle Taulton.
« Reply #13 on: November 13, 2010, 04:49:53 pm »
Well, sadly, nobody has answered my question yet.
Offline Grim 82
« Reply #14 on: November 13, 2010, 05:16:24 pm »
I won't recommend you doing anything one way or the other, but if simplicity is your goal you will need IMO at the bare minimum vacuum to your brake booster, HVAC, and vacuum advance at the distributor. Those are the only lines that I run on my pickup. I put a vented breather on the tank vent hose and removed the canister because mine was hashed. I don't use an EGR or any other emissions equipment.
*edit-  I also run the PCV
« Last Edit: November 14, 2010, 05:43:00 pm by Grim 82 »
