Body, Glass & Paint
Windshield antenna
Topic: Windshield antenna (Read 20352 times)
tmedic
Windshield antenna
November 15, 2010, 11:09:46 am »
I have an antenna inside the windshield but I don't have the button thats supposed to be glued to the windshield. My question is can I just get one off a junkyard donor or does the wires inside the windshield actually come out of the windshield and attch to the button. Mines an 87 V10. Thanks
Re: Windshield antenna
November 15, 2010, 11:14:21 am »
It's not glued on. There is a button that it clips onto.
tmedic
November 15, 2010, 04:31:20 pm »
OK and the button is glued to the window. Right? Do the wires from the antenna attach to the button or is the signal picked up through the glass?
November 15, 2010, 04:54:12 pm »
Why is the actual connector missing off of the glass too?
tmedic
November 15, 2010, 04:57:43 pm »
Yeah I have all the other parts that run from the stereo all the way to include the female connector. Just don't have a button on the glass. Just a gob of dried glue where the button used to be.
zieg85
November 15, 2010, 05:04:30 pm »
At this point you have 2 options... 1 a new windshield because the button connects to the wires, or a fender mounted antenna which works better anyway, get one off a newer 90-91 Blazer or Suburban. My $.02
tmedic
November 15, 2010, 05:09:21 pm »
Dang I was afraid of that. I really don't want to put one in the fender though just a personel preference. Well a new windshield it is
. Thanks
November 15, 2010, 05:21:30 pm »
If the button is stuck in the connector pop it out and use a rear window defrost repair kit and glue it back on.
http://www.permatex.com/products/automotive/specialized_maintenance_repair/auto_glass_lens_repair/Permatex_Quick_Grid_Rear_Window_Defogger_Repair_Kit.htm
tmedic
November 15, 2010, 05:32:30 pm »
I can get another button but will it still pick up the signal if I just glue it to the window?
November 15, 2010, 05:34:04 pm »
The repair kit is just like the rear window defogger. It has essentially a printed circuit that connects to the existing wire. It will work like a charm.
tmedic
November 15, 2010, 05:37:00 pm »
Sweet thanks I will definitely give that a try.
zieg85
November 15, 2010, 08:02:46 pm »
Quote from: tmedic on November 15, 2010, 05:37:00 pm
Good luck, the only time I had tried it, the reception wasn't there.
November 15, 2010, 09:46:46 pm »
Just make sure you get a good connection.
November 16, 2010, 04:26:59 am »
I don’t have any pictures but I had a problem with the button on my truck it was there just something was worn out so it wouldn’t stay connected with the snap so I went and got me 5’ fire sticks and put then on the side of the tool box got the appropriate adapters to set them up to am/fm and went on my way works a lot better than the window or fender antenna. But like vile said if you don’t have a good connection then nothing will work
tmedic
November 16, 2010, 05:25:23 am »
Thanks Will do. What are fire sticks?
Body, Glass & Paint
Windshield antenna
