Author Topic: Fuel Pump Push rod  (Read 4707 times)
Offline chevyman350_82
    • Car domain site...
Fuel Pump Push rod
« on: November 16, 2010, 02:19:10 pm »
Hi Guys I have a question I am putting a engine out of a 93 chevy c1500 in my 85 chevy truck and have no fuel...the engine out of the 93 did not have fuel pump so I bought the push rod and fuel pump for it...is the push rod the same?
Offline screamin86
Re: Fuel Pump Push rod
« Reply #1 on: November 16, 2010, 02:20:49 pm »
The newer engine might night have a lobe on the cam for the fuel pump you may need to run a electric pump with a regulator.
86 ta:lm7 hot cam boltons
« Reply #2 on: November 16, 2010, 02:23:33 pm »
K. Thats what I was beging to think Because after all that time last night winding on it I figured I would have some fuel but thanks man!
« Reply #3 on: November 16, 2010, 02:27:07 pm »
well on second thought when I had it on the stand and put the rod in I spun it over to find top dead center and I saw the rod moving...so I'm not sure
Offline screamin86
« Reply #4 on: November 16, 2010, 04:19:40 pm »
I'd still double check that but it could also be a bad fuel pump.
« Reply #5 on: November 16, 2010, 08:49:29 pm »
If the 93 motor has the stock cam in it, there is no lobe on the cam.
« Reply #6 on: November 17, 2010, 07:05:14 am »
Thanks guys I put new fuel pump on it and it worked fine.
