Author Topic: 85 grille to an 88 grille???  (Read 21505 times)
Re: 85 grille to an 88 grille???
« Reply #15 on: November 25, 2010, 06:37:29 pm »
The 81 and 82 front bumper had the signal holes. The quad headlights were available 83-up
I may have missed something here, but oldyellers 81 is original quad lights, and the 82 I just sold had quad headlights as well. If you plan on changing to the quad headlight, you will need the proper core support, and the grille and headlight bezels will have to be ofthe same year model, or close, so they will match. The will all pretty much bolt on together, but vary in design some.
Offline Grim 82
« Reply #16 on: November 25, 2010, 09:28:14 pm »
My 82 also has original quad headlights.
« Reply #17 on: November 25, 2010, 10:56:17 pm »
Yes 81 up I don't know why I put 83. Maybe I typed it on my phone... sorry about that
Offline project85
« Reply #18 on: November 27, 2010, 02:25:19 pm »
so i have to find a core support that is a quad light? can i cut my core to make it work or is it not worth it? are the grilles different or is the grille the same? i thought someone on here had said the grilles would work. i have an aftermarket billet grille for my truck, and hoped to still use it after converting to the quad lights. will it bolt up or do i need to do some fabricating?
thanks
1985 C-10 Deluxe Step Side
« Reply #19 on: November 27, 2010, 03:22:25 pm »
Get a core support. I have an extra one you can have if you want it... not sure where you're located. The grille will fit.
Offline project85
« Reply #20 on: November 27, 2010, 06:17:21 pm »
im from southern NH right on the mass border. so i need a core support from a dual headlight truck, and i've check a few salvage yards close by and no ones has anything yet. i'm actually leaning toward putting a phantom grille on it that covers the headlights. would that hide anything i would have to do to convert the single headlight to a dual? or am i just stuck finding or ordering a dual headlight core no matter what i do?
Offline topp
« Reply #21 on: November 27, 2010, 06:19:44 pm »
You need the Core support no matter what
'90 Suburban TBI 350
« Reply #22 on: November 28, 2010, 07:27:11 am »
Southern N.H. Hmmm, you must have snuck in while I wasn't looking!!!! From the Newfound lake area myself.
Offline fitz
« Reply #23 on: November 28, 2010, 08:06:07 am »
My 82 had the 4 headlight set up with the directionals in the bumper.
