Author Topic: 85 grille to an 88 grille???  (Read 21504 times)
Offline project85
« on: November 17, 2010, 11:00:04 am »
does anyone make a grille kit to swap a 85 grille to an 88 grille? i like the 85 look but i love the 88 double headlight look. i wanna do that with the directionals in the bumper. not sure if anyone has done that before on here or if you know if there is a kit out there to make this easier.
thanks
1985 C-10 Deluxe Step Side
Offline three8six
Re: 85 grille to an 88 grille???
« Reply #1 on: November 17, 2010, 12:11:11 pm »
81-82 is the year with directionals in the bumper....It's easy though buy the head light buckets, head lights, radiator support, cut the holes in your bumper/buy a new bumper, buy the lights. Nobody sells a "kit" though.
Offline topp
« Reply #2 on: November 17, 2010, 05:11:26 pm »
88 P/U grill or Blazer Grille?
'90 Suburban TBI 350
Offline project85
« Reply #3 on: November 17, 2010, 06:29:58 pm »
i'm looking to convert my 85 single headlight to a dual headlight, then get a bumber that has the directionals in it. or i'll cut my bumper and put the directionals in that. i'm not sure if its a blazer or an 81-82 year. i thought the 88 had dual headlights.
the one in the upper left is the look i want.
« Last Edit: November 18, 2010, 09:56:35 am by VileZambonie »
Offline topp
« Reply #4 on: November 17, 2010, 06:58:23 pm »
I think you need the following-
From an 82-88
Harness for Quad headlights
2 "high beam" buckets
Radiator Support
Both Bezels for Quad headlights
Grille
Offline project85
« Reply #5 on: November 17, 2010, 08:36:33 pm »
so what year had the dual headlights like that? or was it a specific model? i havn't seen anything in the few books i have that is rea clear.
thanks
Offline topp
« Reply #6 on: November 17, 2010, 09:03:39 pm »
The Square Headlight years (82 (I think)-88) had over/Under Optional Quad lights...
89-91 Had side by side Optional quad Lights...
That is for Blazer and Suburbans. In 88, the Pickup went to the new body style and those lights are entirely different..
Offline project85
« Reply #7 on: November 17, 2010, 09:20:20 pm »
So if I order or hunt down stuff for an 82-88 dual headlight set up ill be all set? Is the grille different from an 85? I have a billet grille for my 85 and not sure if it will work with the dual headlights.
Offline topp
« Reply #8 on: November 17, 2010, 09:24:25 pm »
According to some online catalogs , the grille for single/Dual is the same for 85-88
« Reply #9 on: November 17, 2010, 10:11:24 pm »
Thought the quads only came with 85-87. And my 82 had bumper marker lights
« Last Edit: November 17, 2010, 10:12:57 pm by Irish_Alley »
Offline topp
« Reply #10 on: November 18, 2010, 06:17:18 am »
The catalog page the OP posted shows them in 81-82 as well as 83-88
Offline jaredts
« Reply #11 on: November 18, 2010, 06:44:09 am »
I've heard the quad headlights on squarebodies called the "Silverado front end."  Don't know that it was a Silverado only option, though.  My '83 has them.  Either way it was optional.  There's a lot of these in the junkyards, so it should be easy to find the parts used.  Seems to be hard to find a good grill, but they're cheap enough new.  I don't care for the single square headlight, so I would make the switch too if I didn't already have them.
Offline Grim 82
« Reply #12 on: November 18, 2010, 08:48:16 am »
My 82 and 84 Silverados, and 88 suburban all have the over under quad lights, but the 84 and 88 have the turn signals behind the grille. I have only heard of the bumper mounted blinkers on 81 & 82 models. I plan to use the suburban grille and move the blinkers up, and use the holes in the 82 bumper for fog lights.
« Reply #13 on: November 18, 2010, 09:55:26 am »
The 81 and 82 front bumper had the signal holes. The quad headlights were available 83-up
Offline 80stepsideguy
« Reply #14 on: November 25, 2010, 05:43:47 pm »
I agree here, my 83 blazer(sigh wish i never sold it) had the stacked headlights.
1998 Chevy 1500 S/B 2wd
