Author Topic: Epoxy Paint Clogging Gun  (Read 5701 times)
Offline 86gmc23
« on: November 17, 2010, 03:01:16 pm »
Hey guys this is my first time painting and I have a HVLP 1.4mm tip gun and I'm using Eastwoods 1:1 Epoxy Primer Black. I loaded gun with 6oz primer and 6oz of catalyst and the gun clogs with over 4oz still left in gun with almost no down time from spraying. Should I lower the amount of catalyst or am I doing something wrong? Any advice would be great, btw I have gun broke down and all pieces sitting in paint thinner getting ready to clean.
Re: Epoxy Paint Clogging Gun
« Reply #1 on: November 17, 2010, 04:24:13 pm »
Is the paint getting really thick?  What are the temps?  What does the working potlife on the product data sheet say?
« Reply #2 on: November 17, 2010, 04:27:43 pm »
Stir it real good and add a little medium reducer.
Offline 86gmc23
« Reply #3 on: November 17, 2010, 08:27:05 pm »
Looking up specs on the paint, like I should have prior, but it says with a HVLP 1.4-1.8mm tip to spray at 8-10psi. I've been spraying at 35psi, would that contribute to my problem or create another one I don't know about?
And if I add some reducer which it says I can cut up to %20, will paint match with what I've already done?
« Last Edit: November 17, 2010, 08:28:51 pm by 86gmc23 »
« Reply #4 on: November 17, 2010, 08:41:26 pm »
It should match, maybe smoother.  They say 8-10 which is the cap pressure.  Read your HVLP manual, it will tell you what pressure to set it to too achieve the 8-10 psi.  The first generation HVLP guns needed 90 psi to get 9 HVLP pressure.  Recent guns 29 psi gets you 10.  20% reducer will help a lot especially with the 1.4 tip.
Offline 80stepsideguy
« Reply #5 on: November 19, 2010, 04:01:47 pm »
Sounds like your air is making it dry faster cause you got it up to high,Like vile said throw a lil reducer in it and cut the air pressure down a bit.Cause now your going to reduce it and it wont cover as quickly but it will be fine once dry.
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline 86gmc23
« Reply #6 on: November 20, 2010, 02:13:51 pm »
I cut it with reducer just under 20% and it worked good, except after spraying around 20oz when I ran out the separator was pretty clogged at bottom of tank. So I broke gun down after each time and it had some chunky paint in it as well. Was spraying at 35psi at compressor. Without the reducer the tip clogged after about 8-10oz.
