Author Topic: Useful life of vital fluids?  (Read 4655 times)
Offline got2haul
« on: November 24, 2010, 06:36:41 pm »
Brake fluid?  When should it be changed?
Oil?  3 months or 3000 miles is common knowledge.  What about a vehicle that is only driven a few hundred miles each year?
Other fluids?
I bring this up because I have a '89 C1500 that belonged to my dad that I drive around 300-500 miles per year.  57K miles right now.
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
Re: Useful life of vital fluids?
« Reply #1 on: November 24, 2010, 06:55:06 pm »
     With all fluids there is a viscosity rating, a expert would tell you to change when the viscosity starts to break down, but since we don't have chemical labs in our basements a good rule of thumb is when they change color excessively then change them.
Offline 1984k30
« Reply #2 on: November 24, 2010, 07:06:03 pm »
I thought the viscosity of the oil never broke down just the additives in the oil?
Offline topp
« Reply #3 on: November 24, 2010, 07:07:43 pm »
Oil holds moisture and contaminants from the combustion process.....
I change it at 3000 miles or 3 months regardless...
'90 Suburban TBI 350
« Reply #4 on: November 24, 2010, 07:19:12 pm »
If the vehicle isn't being driven, changing the oil every 3 months is a pointless. If it isn't being used that much and is stored in a dry environment use a good synthetic and change it two to three times a year.
Gasoline is the worst fluid to let sit. Run a fuel stabilizer as well.
Dot 3 brake fluid is hygroscopic which means it absorbs moisture. Change it biannually.
The other fluids just use your judgment.
Offline 84chevysilverado
« Reply #5 on: November 24, 2010, 08:01:21 pm »
Some fuel stabilizers are actually worse then just old fue.some fuel stabilizers will also start to break down after a while. I personally stay away from fuel stabilizers just my 2 cents
« Reply #6 on: November 24, 2010, 08:05:23 pm »
Then don't buy your fuel stabilizer from Ocean State Job Lot
