Author Topic: Brake Pull  (Read 3870 times)
Offline rainman15
  • Steve
Brake Pull
« on: November 29, 2010, 01:53:12 pm »
84 GMC K-1500 SWB.  I replaced my front pads, calipers and rotors because I was getting a little pull to the left under hard braking.  I figured I had a caliper that was sticking, or just getting old so I replaced everything up front. The truck still pulls to the left when I brake.  Is there any chance the back brakes could be causing this?  Any suggestions?
84 GMC High Sierra 4x4 shortbed
09 GMC Sierra SLT
09 Mercedes Benz C-350
60 Chevrolet Impala
Offline Da67goatman
  • Burban
Re: Brake Pull
« Reply #1 on: November 29, 2010, 02:01:25 pm »
How's your alignment?  Could be pulling because one wheel has more toe than the other.  Could also be a bad wheel bearing, causing binding on that side.  I would also check your rear brakes to make sure they are engaging at the same rate.
<Pitcrew>
Re: Brake Pull
« Reply #2 on: November 29, 2010, 02:19:07 pm »
If the front end is tight, replace the brake hoses.
Re: Brake Pull
« Reply #3 on: November 29, 2010, 07:36:22 pm »
x2
Offline rainman15
  • Steve
Re: Brake Pull
« Reply #4 on: November 30, 2010, 08:19:10 am »
Will do.  Thanks guys!
Steve
09 GMC Sierra SLT
60 Chevrolet Impala
