Author Topic: yoke dust shield  (Read 4883 times)
Offline ngarman123
yoke dust shield
« on: November 29, 2010, 08:31:11 pm »
what would cause my rear yoke dust shield to grind on the pinion oil seal lip? it looks like the seal is seated properly. the pinion?
Re: yoke dust shield
« Reply #1 on: November 29, 2010, 09:40:12 pm »
Did it break loose?
Offline ngarman123
« Reply #2 on: November 30, 2010, 07:24:46 am »
no i replaced the seal and was not aware that i needed to mark the nut. so i removed everything without marking a thing and now it is hitting the seal when i put everything back together. i am trying to get by for this winter and rebuild the rear axle next spring. the truck will not be drove much at all. i know i should take the axles and carrier out to properly set the pinion preload. but like i said i am trying to get by this winter.
« Reply #3 on: November 30, 2010, 11:10:18 am »
So you overtightened the pinion nut?
Offline ngarman123
« Reply #4 on: December 01, 2010, 08:13:35 am »
possibly but not sure?
