Author Topic: carb identifying question  (Read 4203 times)
Offline txchainsawgogi
« on: December 01, 2010, 03:47:42 pm »
So I've got a carb in my 1978 C10 350 5.7l auto with the number 17058213 BJB2527.
Did this carb come out of a different truck? Namely a manual transmission truck...
It would explain why it feels a little off, as the previous owner did a lot of crap to it 1/2 A**'d.
With a rebuild...will this carb function fine with this engine/tranny, or should I search for the original carb?
Offline topp
Re: carb identifying question
« Reply #1 on: December 01, 2010, 04:14:10 pm »
According to http://www.carbguy.com/info.php  :
Make & year  GMC/Truck, 1978
Displacement/cylinders  350/8
Carb number  17058213
A/T H.D Truck also 1979
'90 Suburban TBI 350
« Reply #2 on: December 01, 2010, 06:03:45 pm »
Found my clymers manual...its not even in that book. Found a site that says odd numbers where the three is (1705821 >3< 2377), means manual tranny. So confused.
Went to change my fuel filter an looked up the part # at autozone, the one their comp shows for my make and model was way too long. So I know I can't have the original carb.
Offline 756man
« Reply #3 on: December 01, 2010, 11:58:20 pm »
Computers are only as smart as the person, that puts the info in them. Lots of errors get entered everyday. I say you have the correct carb.
1985 Chevy K-20 longstepside, 350,Turbo 400
Offline Grim 82
« Reply #4 on: December 02, 2010, 08:58:55 am »
The q-jet off of my 82 that was originally a manual trans didn't have the provision for a kickdown cable on the throttle linkage. As long as your carb has it you should be good to go.
« Reply #5 on: December 03, 2010, 09:17:07 pm »
How's "tomco" with their rebuild kits? Garbage? Its all I see on ebay. Help! My carb is leaky!
« Reply #6 on: December 05, 2010, 05:50:47 pm »
Found a decent deal on a rebuilt rochester. Gonna go that route... I'm sure there's plenty wrong with mine other than its seals.
