Author Topic: Need a measurement  (Read 13420 times)
Re: Need a measurement
« Reply #15 on: January 29, 2011, 05:39:51 pm »
OK bringing this one back from the dead. Anyone with a 2wd 73-80 with a leaf spring suspension, please help me out here. With the vehicle on the ground give me a measurement on the drivers side of the frame to the center of the axle. I want to make sure my measurements are accurate. Use the above pictured hole as your point of reference. I'll explain after why I'm questioning a few things. Thanks
Offline 1979C20
  • Kyle Taulton.
« Reply #16 on: January 29, 2011, 05:50:49 pm »
I have a bone stock 79 c20. From where to where do you need measured.
« Reply #17 on: January 29, 2011, 07:47:56 pm »
Straight up from the center of the axle and a reference on the frame to the elongated hole.
Offline 1979C20
  • Kyle Taulton.
« Reply #18 on: January 29, 2011, 09:28:05 pm »
Okay, its dark out right now, but I will get that as soon as I can.
« Reply #19 on: January 31, 2011, 09:32:57 pm »
I can probably get this for you tomorrow, it is raining here right now.  Shoot me an email tomorrow evening and I will check.
Offline 1979C20
  • Kyle Taulton.
« Reply #20 on: January 31, 2011, 09:49:23 pm »
Okay, the center of my axle tube is about 1 and 1/8th" forward, toward the engine, from the left edge of the elongated hole. I cant get an exact without taking my tire off.
« Reply #21 on: February 01, 2011, 09:28:04 am »
Wow, yours is going the opposite direction of the last two I measured. Anyone else care to throw a measurement ?
Offline 1979C20
  • Kyle Taulton.
« Reply #22 on: February 01, 2011, 12:50:01 pm »
I thought it was odd yoo. And I tripple checked my findings to make sure I wasnt tripping. But thats with bone stock suspension. Does it matter that mine is 3/4 ton? Ill check my buddies truck tonight too. His is also a 3/4 ton.
« Reply #23 on: February 02, 2011, 08:51:38 pm »
It's got to be a short bed....
Offline 1979C20
  • Kyle Taulton.
« Reply #24 on: February 02, 2011, 09:29:12 pm »
Ohhhh. That would be the cause. We both have ling beds. Sorry vile.
« Reply #25 on: February 03, 2011, 07:31:24 pm »
I figured it all out tonight. I'll post the results of my findings when I document the conversion.
