Author Topic: 73-80 Style Frontend on an 81 c10  (Read 5051 times)
Offline 81TruckGuy
« on: December 05, 2010, 12:25:42 pm »
I was wondering if the 73-80 style front end would fit on an 81 style body? Would it work with my 81 fenders, or would I need different fenders? Just looking at it, it looks like I would need a new front grill assembly and hood, but I'm not sure about the fenders. If I had to replace the fenders, would they line up with my doors?
Re: 73-80 Style Frontend on an 81 c10
« Reply #1 on: December 05, 2010, 12:30:57 pm »
From the doors forward, 73-80 and 81-87 are one or the other. The parts don't mix and match. You can put the 73-80 front clip on the 81 up cab with a few slight modifications.
Offline 80stepsideguy
« Reply #2 on: December 05, 2010, 10:02:32 pm »
Also be aware that your going to need to use shorter windshield wiper arm mecanism under the cowl to the 73-80 nose as its shorter to compisate from the 81 n up cowl panel.But like vile said it will be a simple swap.Also plug off the holes on the cowl for where the 81 n up hood hinges were once as well as the holes where the cowl panel on your 81 sat in as well..
thanks
Pat
« Last Edit: December 11, 2010, 09:29:23 am by 80stepsideguy »
1998 Chevy 1500 S/B 2wd
