Interior & Equipment
Sub box for my Burban
Topic: Sub box for my Burban (Read 12286 times)
Da67goatman
Site Supporters
Burban
December 09, 2010, 03:32:31 pm »
Subs have been on my to-do list for a while, so I thought since its cold and snowy out, I can build this box inside where its warm. I am putting 2 12's in a round box in the spare tire well then hiding them using the factory spare tire cover, sneaky sneaky. the hard part was figuring out how to make plywood round. So I got a sheet of 1/4" plywood and cut it into 9" strips and will glue the strips together in a circle 3 layers thick totaling 3/4" then capping it with 3/4" top and bottom
Will post pics as it develops.
<Pitcrew>
1992 fullsize Blazer 4x4 35s no lift, 4.10s, Hella driving lights, TJ Flares, Huge bumpers, Snorkel, custom interior
Da67goatman
Site Supporters
Burban
Re: Sub box for my Burban
December 10, 2010, 12:33:57 pm »
So I got 3 layers glued and screwed, this is where I stand, Its slightly larger than I wanted 35in diameter. i still have to sand and plane the edges and put the top and bottom on, and divide it for each sub.
<Pitcrew>
Grim 82
December 10, 2010, 01:41:00 pm »
That is awesome. Nice work.
1980c10
December 10, 2010, 04:48:08 pm »
looks great. I did a larger version of curving plywood on a rounded stairwell, I found that a paint roller and pan full of wood glue work great.
Da67goatman
Site Supporters
Burban
December 11, 2010, 12:01:03 pm »
Yes a roller and a pan of glue work great. Also used lots of screws to overkill everything together.
<Pitcrew>
captain carnage
December 11, 2010, 12:53:01 pm »
Thats a great idea, I like it.
Da67goatman
Site Supporters
Burban
December 11, 2010, 07:18:38 pm »
So i put the divider in and planed/ sanded all the edge flat, and put sound deadening padding along the inside. I just have to make the top and bottom and seal them to this piece.
<Pitcrew>
Da67goatman
Site Supporters
Burban
December 14, 2010, 04:57:22 pm »
Got the top and bottom cut out, the bottom is glued and screwed. Still have to finish sound dampening and get top put on.
<Pitcrew>
SUX2BU99
December 17, 2010, 02:38:22 pm »
Right on. I know of a guy who had a mid-90s Sub and put 3 8's in a sub box that looked like a spare tire. He decided to use multiple layers of 3/4" MDF all cut into rings. That took a lot of rings! Guess he didn't mind the price of buying all that wood only to waste most of it.
Da67goatman
Site Supporters
Burban
December 17, 2010, 04:18:15 pm »
8s? what good is an 8? By my calculations I have 2 cu ft per side, so I'm looking for 2 big 12s or decent sized 15s. depth is the only issue, good quality subs are pretty deep and I only have 10" to work with.
<Pitcrew>
SUX2BU99
December 22, 2010, 03:15:05 pm »
You must have never heard a good set of 8's in a decent system. I've heard plenty. Not much else though can belt out some fat, fat bottom end (like 30 Hz and down) like a pair of 15's though.
73ratrod
May 01, 2011, 02:18:36 am »
plywood will never work unless u silicon the holeee inside of the box and u divided it so the 15 wont work plus looks like its kinda a tight space for 12s maybe 10s
plywood doesn't make good boxes cuz the poor layer gluing which allows to much air to escape
.........________//__{\_____
,,,,,,,,,/__(O)__/____/_(O)_/chevy
1979C20
Kyle Taulton.
May 01, 2011, 02:37:14 am »
Old thread is old. Out of all of the many sub boxes I have seen, only like 3 of them werent made of.plywood. Those 3 were fiber glass. And the plywood ones sealed great. A completely non ported box with 1 twelve sealed to the point that when you pushed the cone in, it pushed back from the air that was inside and then took several seconds to come all the way back out.
beastie_3
Josh
May 01, 2011, 01:58:41 pm »
your supposed to use MDF, not plywood.
Semper Fi
big bear
May 01, 2011, 02:46:59 pm »
i was just about to say mdf is what i always use. .... unless people are calling mdf plywood. i hope they are. i couldnt imagine building a box out of plywood.
