Performance
Carb question
Topic: Carb question (Read 24770 times)
1979C20
Kyle Taulton.
Carb question
December 12, 2010, 03:31:14 pm »
Would a Holley 750cfm double pumper part#r84013 be too much for a basically stock 350 with a 440 292 comp cam? Stock heads, stock crank, stock pistons, stock intake, stock distributor, headers, about 2000mi on engine. Daily driven, like its a race car. Haha. I only get about 8 or 9mpg with my stock qjet that needs replaced/rebuilt. So I dont expect much mileage.
Re: Carb question
December 12, 2010, 11:04:37 pm »
Yes.
1979C20
Kyle Taulton.
Re: Carb question
December 13, 2010, 01:00:10 am »
Really? I searched online and was told the stock rochester q-jet was a 750-800cfm....
Re: Carb question
December 13, 2010, 04:14:14 am »
The quad can be tuned on to run that much. A Holley you want no more than 650 with a stock engine. You will find if you want better gas mpg than your gearing should be lower than it is and drive it like an old man
Grim 82
Re: Carb question
December 13, 2010, 09:23:11 am »
To save money and get better mileage rebuild the q-jet. If you just want a shiny new carb a 600 cfm Edelbrock or Holley would be plenty for a stock 350. You would need the adapter plate to put it on your stock manifold if you buy a square bore carb.
Re: Carb question
December 13, 2010, 11:31:05 am »
Q-jet is MAX Flow of 750-800cfm. It runs on 2 small primaries for the most part and the secondaries work on Vacuum demand, generically speaking the motor will only pull what it needs.
A double pumper has a mechanical secondary and when it is engaged it will dump the fuel in regardless if it needs it or not.
1979C20
Kyle Taulton.
Re: Carb question
December 13, 2010, 02:16:23 pm »
How do you bolt the adapter plate on? My dad had on in the shed out back, mr. Gasket square to spread. It has 4 2sided studs, 4 nuts, and 4 washers.
Re: Carb question
December 13, 2010, 03:13:35 pm »
Bolt it to the intake then bolt the Carb on
1979C20
Kyle Taulton.
Re: Carb question
December 13, 2010, 04:05:26 pm »
But how? I dont understand how it would bolt on.
Grim 82
Re: Carb question
December 13, 2010, 04:12:52 pm »
There should be recessed holes to bolt it to the intake, then 4 studs that thread into the adapter, then put the carb on the studs and put nuts on them.
1979C20
Kyle Taulton.
Re: Carb question
December 13, 2010, 04:19:20 pm »
Anybody have pictures of how to install one? Because there are several holes and what now. Like I said, I have 4 2 sided studs, one side is course thread that I believe threads into the intake manifold, and the other side is fine thread which matches the 4 nuts.
Grim 82
Re: Carb question
December 13, 2010, 04:28:37 pm »
And you need 4 bolts to bolt the adapter to the intake. The fine thread end of the studs thread into the adapter. Make sure you use 2 gaskets.
Grim 82
Re: Carb question
Reply #12 on:
December 13, 2010, 04:35:19 pm »
http://www.4wheelparts.com/aux_incl/pdf.ashx?pdf=2696_2697_SqBoreCarbtoSpre.pdf&line=EDE
1979C20
Kyle Taulton.
Re: Carb question
Reply #13 on:
December 13, 2010, 05:22:35 pm »
There are no threaded holes on the adapter plate. how does it bolt to the intake and carb? nuts on either side of the plate?
Grim 82
Re: Carb question
Reply #14 on:
December 13, 2010, 06:03:03 pm »
Lets see a pic of the adapter.
Performance
Carb question
