Author Topic: Power steering box interchange ...  (Read 13857 times)
Offline brimac50
« on: December 14, 2010, 11:25:47 am »
I might be  replacing a sloppy power steering box, on my 1980 3/4T, 2wd.  What newer year boxes , are a direct bolt-in replacement?
Thanks
« Last Edit: December 14, 2010, 11:33:57 am by brimac50 »
Re: Power steering box interchange ...
« Reply #1 on: December 14, 2010, 04:58:05 pm »
Generally speaking 1973-80 for standard.  1981-87 for metric.
Offline brimac50
« Reply #2 on: December 16, 2010, 10:56:10 am »
Do all those years have the same diameter and spline count, on the steering column shaft, or .......  are there some variations?   Also, are all power steering box shafts,  (to rag-joint) , the same?
Offline Tater502
« Reply #3 on: December 16, 2010, 11:10:19 am »
I put the steering box of a 90 4x4 blazer on my 79 4x4 gmc. The only difference is the hose fittings that go into the box.
Andy
Offline snibook7537
  • Vince Ziolkowski
« Reply #4 on: December 18, 2010, 05:53:09 pm »
I am pretty sure there is a difference between 4x2 and 4x4
1984 Fiero se pwr windows Holley TBi, cam, 86 5spd
1987 GMC V3500 350 TBi 4spd 205 t-case
Shoulda never sold:
1976 c-10 beater 250-6 4spd no pwr steering, brakes. Recycling truck
« Reply #5 on: December 18, 2010, 08:00:55 pm »
Correct
Offline 1979C20
  • Kyle Taulton.
« Reply #6 on: December 18, 2010, 09:05:01 pm »
I put the power steering box from an 86 4wd burban on my 79 c20. Direct bolt up. Only thing I can tell that is different is the pitman arm I believe. And it makes my trucks turning much more reactive to the wheel and its misaligned slightly to the left, so my wheel is about a 16th turn to the right to go straight. Only thing I can tell. But, the powersteering box may have been replace with a 2wd one on the burban before I got it, I wouldn't know.
