Author Topic: in line fuel filter  (Read 7476 times)
Offline 1979C20
  • Kyle Taulton.
in line fuel filter
« on: December 15, 2010, 01:17:03 am »
When I rebuilt my engine, I forgot to put the steel fuel line behind the alt and smog pump, so I cut the steel lines and ran rubber from the pump to the carb. Well, I decided to add a fram in line filter to my hose for when I replace my carb. Hardly any fuel is in the filter. It still runs, but it really looks like it shouldn't. Its a new mechanical fuel pump. Yet, it doesn't look like its pumping. My friends 76 fills his in line filter. And so does my dads jeeps. Any thoughts?
Re: in line fuel filter
« Reply #1 on: December 15, 2010, 05:22:00 pm »
It isn't supposed to be filled.  There is nothing wrong.
Offline 1979C20
  • Kyle Taulton.
« Reply #2 on: December 15, 2010, 10:26:20 pm »
What about my dads jeeps and my friends truck? There's are pretty much full. Mine has barely any in the bottom of the filter, and I can see the fuel coming from the line. But, the fuel level no where near reaches the top fuel line to the carb.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #3 on: December 16, 2010, 09:32:44 am »
If it's mounted in a rubber hose you can hold the "to carb" end upwards to fill it more.  If it's hard mounted there's nothing you can do but tip the whole truck. ;) It won't hurt anything like it is though. Mines not even 1/4 full and my truck runs fine up to 4500RPM.  It used to bug me, but I've assimilated that as normal so I'm good now.
Offline 1979C20
  • Kyle Taulton.
« Reply #4 on: December 16, 2010, 10:13:54 am »
Well, its still running, so I'm not WORRIED about it. I'm just..... Perplexed? Why would 3 other vehicles fill their fuel filter and mine barely has any fuel?
Offline Psycho71
« Reply #5 on: December 16, 2010, 06:22:50 pm »
Easy fix for that........Get a filter you can't sent thru, then you'll never know how full it is.  :P
Seriously though, all the clear filters I've ever seen on stock fuel pumps keep a lower level like you describe when  mounted horizontally. When mounted vertically, they get full. Either way, like said above, as long as they keep the bowl on the carb full it's not an issue.
Offline 1979C20
  • Kyle Taulton.
« Reply #6 on: December 16, 2010, 06:56:39 pm »
Well, it is mounted almost vertical, and its practically empty.
  • Z62 ON-ROAD
« Reply #7 on: December 16, 2010, 07:29:27 pm »
That's weird ^^
Offline 1979C20
  • Kyle Taulton.
« Reply #8 on: December 16, 2010, 07:36:23 pm »
See what I mean?
Offline 756man
« Reply #9 on: December 16, 2010, 10:29:18 pm »
If it is running fine, who cares if the filter is full of fuel ?
1985 Chevy K-20 longstepside, 350,Turbo 400
Offline 1979C20
  • Kyle Taulton.
« Reply #10 on: December 16, 2010, 11:52:16 pm »
Well, it bothers me. I have OCD. Hahaha.
« Reply #11 on: December 17, 2010, 10:07:19 am »
Take a look at this picture and maybe this will make it easier to understand. It's normal to see the fuel filter partially full
« Reply #12 on: December 17, 2010, 10:18:52 am »
kind of what vile said but once it gets dirty it will rise lol and if you put it on upside down ::)
