Author Topic: 87 v3500 death wobble  (Read 23615 times)
Offline snibook7537
  • Vince Ziolkowski
« on: December 18, 2010, 05:52:21 pm »
I have an 87 v3500 in stock form ( no lift, suspension upgrades/changes). I have been experiencing a lot of death wobble lately it occured once when I first got the truck and has been increasingly occurring. This happens at any speed if I hit potholes or bumps.  I have done a dry turn and had a friend look and he said nothing looked abnormal, I did not have him look at the steering box (forgot) but When I got it there were no cracks that you could see and I have seen one with cracks. This wobble will only stop if I slow almost to a stop, it is only left to right not up and down or back and forth. I have read on this forum that it could be ball joints on a 4x4 but I thought a Dana 60 had kingpins and I am not sure how to check them.  The truck does have a Meyers plow on it but it did do it before the plow was on the plow frame so I don't *think* that would have to do anything with it. I did notice that it seemed like it did it a lot worse one day after smashing the plow into a pile of snow but it did happen before that.  On a side note I have been experiencing a sort of clunking noise when in second gear and only in second (might have happened once in third but never in fourth) I am hoping it is the transmission as it already needs a rebuild ( falls out of 3rd). I don't think this would have anything to do with the wobble but it is abnormal and I figure you never know. Also should say that it wobbles and makes the clunking noise when hubs are unlocked and when locked in 2wheel and 4 wheel high. I haven't been in 4 lo except twice so don't know about that.
1984 Fiero se pwr windows Holley TBi, cam, 86 5spd
1987 GMC V3500 350 TBi 4spd 205 t-case
Shoulda never sold:
1976 c-10 beater 250-6 4spd no pwr steering, brakes. Recycling truck
Re: 87 v3500 death wobble
« Reply #1 on: December 18, 2010, 07:33:02 pm »
Have you checked the wheel bearings yet. Jack up a corner and wiggle each tire
« Reply #2 on: December 18, 2010, 10:39:55 pm »
Redo the dry park check while YOU check out the front end and the frame etc for movement. After that check your ball joints and wheel bearings. Tire balance, steering stabilier can cause it too.
Offline snibook7537
  • Vince Ziolkowski
« Reply #3 on: December 20, 2010, 12:56:00 pm »
So now my friend turned the wheel and I checked the front end and I found that the pitman arm seems to have a bit of play in it. Unfortunately I don't know if this is enough to cause the wobble. How much play is too much and could that be responsible for the wobble.  I think this is likely the issue as the frame near the steering box and the steering box itself is stationary the entire time(not broken/cracked).
Shoulda never sold:
Offline 1979C20
  • Kyle Taulton.
« Reply #4 on: December 20, 2010, 02:00:12 pm »
My truck has quite a bit of play in the steering wheel. I can turn it about 4/5inch before it turns the tires. Driving above 35 mph I get a bit of death wobble. I haven't adjusted the play in the steering box yet, and I know that is the problem. So, adjust your gears or replace your box. I'm not sure how to adjust it on newer vehicles, but maybe someone else on here can help.
Offline Grim 82
« Reply #5 on: December 20, 2010, 02:16:16 pm »
Replace any obviously worn parts before you mess with your steering box.
Offline 87454westernhauler
« Reply #6 on: December 20, 2010, 02:20:52 pm »
my dad has an 87 r30 1ton dually that sounds kind of like what yours is doing. have you replaced the bushings in the front suspension ever? how good are yours tires alighned?
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Offline thirsty
    • Suitor's Garage
« Reply #7 on: December 20, 2010, 02:42:12 pm »
I bought a truck once that came with the death wobble. It turned out to be a bad tie-rod end and a worn stabilizer shock.
Offline ehjorten
« Reply #8 on: December 22, 2010, 01:32:17 pm »
Upper King-pin bushings are a good place to start on the Dana60.  They are inexpensive and easy to replace.  Jack it up, put a jack under the knuckle to keep upward pressure on it, 4 bolts to unbolt the top cover and pull out the spring and bushing.  Replace with new spring and bushing and put back together with a new gasket.  Have lots of grease on hand to re-grease.
-Erik-
Offline snibook7537
  • Vince Ziolkowski
« Reply #9 on: December 23, 2010, 07:14:10 pm »
I found the problem, it is a tie rod end that attaches to the pitman arm. I think I am going to get a dampener just cause too.  The tires and bearings and the gearbox are all good.  Thanks for the help guys
Shoulda never sold:
Offline rwhit57
« Reply #10 on: January 03, 2011, 03:45:13 pm »
Death wobble is caused by toe-out, obviously it can be worn parts especially tie rod ends. It occurs when one wheel toes out then tries to correct itself forcing the other tire in and out, etc. Once you replace the worn parts an alignment is a must. Sounds like you found the cause, good luck.
Randy from Okla
Whoever said "Money can't buy happiness" has obviously never seen a speed shop!
Offline KY..Rob
« Reply #11 on: January 03, 2011, 05:44:43 pm »
« Reply #12 on: January 03, 2011, 07:34:05 pm »
Who told you that?!
Offline rwhit57
« Reply #13 on: January 03, 2011, 07:53:03 pm »
« Last Edit: January 04, 2011, 05:03:02 pm by Captkaos »
Randy from Okla
Offline snibook7537
  • Vince Ziolkowski
« Reply #14 on: January 21, 2011, 02:09:34 am »
don't mean to bring this from the dead but I actually replaced the steering dampener and what a heck of a difference that made.  The tie rod was worn out but I could have probably just put that dampener and it would have gotten rid of the death wobble.  Not saying I would do it as the tie rod was worn out but if you think that it might be a problem take it off and look.  Mine you could EASILY push in and I put it on the bench in my garage and it never released.
Shoulda never sold:
