Author Topic: I'm sure it's been talked about.....  (Read 10879 times)
Offline ToddN
« on: December 19, 2010, 06:28:12 pm »
Could someone direct me to a past thread title concerning cutting out partial bed panels and tacking in new ones.  I'm beginning the research phase of replacing right and left fleetside panels but I'm not replacing the whole panel because the rest of it is mint.  Just around the wheel wells.  Thank you.
A government big enough to give you everything you need, is a government big enough to take everything you have.
Re: I'm sure it's been talked about.....
« Reply #1 on: December 19, 2010, 06:34:20 pm »
which section are you planning on patching?
Offline Cody1018
« Reply #2 on: December 19, 2010, 06:37:00 pm »
1986 Chevy K10 Silverado
Offline ToddN
« Reply #3 on: December 19, 2010, 07:07:45 pm »
I should rephrase.  Wheel arches. :P    60 inches long and 29 inches tall.http://www. competitor.com/icatalog/cc/full.aspx?Page=27   Its part number 6.  I dont know if thats where I'll get them but thats the part.
Offline ToddN
« Reply #4 on: December 19, 2010, 07:10:27 pm »
73-87   catalog.  On the bed panels page it's #6.
Offline topp
« Reply #6 on: December 19, 2010, 07:22:08 pm »
Will either of those fit Blazers?
'90 Suburban TBI 350
Offline ToddN
« Reply #7 on: December 19, 2010, 08:27:38 pm »
Yes Cody those are the ones.  I know how to MIG weld and thats about it.  Ive never done anything like it.  Thats the only place where there is rust on the truck and its been rapaired before.  I just want to cut the whole section out and be done with it.
Offline 1980c10
« Reply #8 on: December 19, 2010, 08:45:36 pm »
I used that type of patch panel on my truck, but not the whole piece.
Just cut out only as much as you need, lay the peice over the old and trace a pattern, cut out the old and tack weld the new in as perfect as you can and continue to weld different spots a little at a time until it is welded completely.
when you cut the new panel; try to cut it where you'll be able to fill and sand it the easiest, ie. you don't want to end it on a body line if you can help it.
Offline ToddN
« Reply #9 on: December 20, 2010, 01:37:14 pm »
I'm getting nervous about doing this myself.  This isnt a show truck but its my daily driver and I wanna keep it straight.  To cut those parts out and weld and finish both sides with primer and no paint, what would be reasonable to pay someone? ::)
« Reply #10 on: December 20, 2010, 04:46:59 pm »
If you're going to patch it use panel pond ahesive. Where are you from? If you haven't done major body work you may want to pay someone to do it.
Offline ToddN
« Reply #11 on: December 20, 2010, 05:35:00 pm »
I'm from Maine.  I haven't done major body work either.  I called a body man on Craigslist who has found himself out of work.  Maybe him?  The truck is flat black.  I'm not real concerned with the finish work goes but I want it to be straight, welded correctly and primered.  I'll spray the flat on. ;D  This guy has a bodyshop out of his garage.  I'm not sure how to figure out a fair price though.
Offline 1980c10
« Reply #12 on: December 20, 2010, 07:08:18 pm »
check with some smaller body shops, if you like their price go with it, if not; someone working out of their garage i would think half of what a bodyshop would charge. It's a little risky not using a shop so the price should reflect that.
Offline ToddN
« Reply #13 on: December 21, 2010, 09:30:44 am »
OK..thanks.  I'll call around and get a ballpark and throw a number at him.  Or, maybe he'll throw a number at me and tell me to stuff it. :-\  Or maybe I could trade some carb work.  Ya never know until you start gabbing with the guy.  Ive got a clean 350 block to throw in and what not.
Offline thirsty
    • Suitor's Garage
« Reply #14 on: December 21, 2010, 09:36:13 am »
Think about talking to someone that had him do rust repair before and see if you can look at his work to see how it looks and holds up.
