Author Topic: Who makes a front receiver hitch for 87 R-10?  (Read 7799 times)
Offline Dieselfume
« on: December 24, 2010, 02:59:18 am »
Been thinking of a front hitch for the truck, so I can have the hitch haul in back, and the bike rack in front. I also have a receiver mount with a HD geared boat winch in case Murphy strikes, or for dragging stuff into a trailer, etc.
I did quite a bit of searching, reese, curt, valley, summit, uhaul, ebay, etc. No joy. 88+ they have, but not 73-87 anymore. I see two previous posts here where folks made custom hitches. (the hidden one is pretty slick) As much as I'd like to play with my welder, I really would rather bolt something on and not spend a weekend or two fabricating a proper hitch.  Perhaps there's another hitch application that is close enough to drill holes or just directly weld on?
Dieselfumes-aka-Tom
81 Buick Regal Limited, Olds LF9 5.7L (The Neglected Project)
93 Olds Ciera S 3300 daily driver, 285k+
87 Chevy R-10 Silverado 305TBI/700R4 58k, stock 2wd 33x10.5-15 BFG AT, camper shell, Janesville Assembly
Offline 74k20
Re: Who makes a front receiver hitch for 87 R-10?
« Reply #1 on: December 24, 2010, 03:29:17 pm »
You will have to fabricate one up.  Finished my front hitch install just last weekend and it came out great.  I used a rear hitch, cut/welded/drilled/re-cut/ground/re-drilled/re-cut ect.  Have yet to use it, but I also have a heavy duty 2 spd boat winch mounted to a reciever hitch.  Along with a basket, bike rack, motorcycle rack, soon a lift hoist ect.
Search for a post a few months ago with some details from another member.
Good luck,
MJ
Offline Da67goatman
  • Burban
« Reply #2 on: December 24, 2010, 03:33:25 pm »
I made my own as well from a rear hitch, check the link.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=16550.0
<Pitcrew>
Offline 74k20
« Reply #3 on: December 24, 2010, 07:18:41 pm »
That's the link above that I was thinking of.  I soooo tried the hidden hitch behind the lic plate, but my receiver wasn't the best fit.  It was just right for a below however, so that's the direction I went with.
Thanks da67goatman for the idea and insperation to start the project.
mj
Offline Da67goatman
  • Burban
« Reply #4 on: December 24, 2010, 07:21:07 pm »
I have no problem sharing ideas as long as I get credit for em.  ;)  Your welcome.
<Pitcrew>
