Author Topic: A/C-Heater Blower Motor  (Read 31215 times)
Offline AdrianR
  • Big Blue Beastie - '85 Suburban K10, 6.2 diesel
« on: December 31, 2010, 01:04:21 pm »
Folks, I'm thinking this is due for replacement - along with a general service of the blend flaps etc - but how do I access it? From the engine bay or from inside the cab?
Chevy lover
1985 Suburban K10 Silverado diesel
Offline Da67goatman
  • Burban
Re: A/C-Heater Blower Motor
« Reply #1 on: December 31, 2010, 02:32:27 pm »
Both its 2 halve that bolt to the firewall, the heater core is inside with the flaps and the AC and blower motor are on the under hood part.
This is the under dash part.
<Pitcrew>
« Reply #2 on: December 31, 2010, 03:50:36 pm »
There really is no general service to the distribution plenum and actuators. Unless there is an issue they are essentially maint. free. So what is the problem? Low flow?
Offline AdrianR
« Reply #3 on: January 01, 2011, 11:47:39 am »
... So what is the problem? Low flow?
There are two issues.
1. There is  low/poor air volume/flow even (with the blower at max). The blower motor isn't making any strange noises to suggest it's dying but the airflow seems like it should be better than it is.
2. The A/C temperature is fine but the airflow from the vents seems to decrease as the truck goes faster. At 60mph and with the blower on max, there's just a faint breath of cold air.
Any suggestions as to where I should start looking?  :-\
Chevy lover
Offline acefoxx
  • 84 SierraClassic stepside/85 K5 Blazer
    • Acefoxx.com
« Reply #4 on: January 01, 2011, 12:11:44 pm »
subbed. I would like  some advice on this also. My blazer seems to have a tired blower also.
'84 GMC SierraClassic/'85 K5 Blazer Silverado
http://acefoxx.com
« Reply #5 on: January 01, 2011, 03:48:35 pm »
Make sure the vacuum reservoir is hooke up and the heater control is tapped into it also.
Offline AdrianR
« Reply #6 on: May 24, 2011, 10:17:25 pm »
Brief update for info.
Replaced the blower motor ($20 for a reman unit from Pep Boys) and things are better.
The volume of air seems the same (I guess it would be as the blower wheel and motor rpm are the same) but there seems to be more 'oomph' at the dash vents now.
Chevy lover
Offline 1979C20
  • Kyle Taulton.
« Reply #7 on: May 25, 2011, 01:53:26 am »
You could always use a late model blower motor for more air flow.
Offline Skunksmash
« Reply #8 on: May 25, 2011, 01:59:18 am »
Do you happen to know which late model, specifically, would push more air? I am having the same problem. Low air volume making it out the vents.
Also my air cuts off completely after its been running on the high fan setting for a few minutes.
Offline Grim 82
« Reply #9 on: May 25, 2011, 08:56:24 am »
I use the blower motor from a 94 chev pickup. If you have AC it will be a direct replacement, but I have heard that they will not fit in a non-AC box. It's been my experience that low air flow in the vents is almost always because of a vacuum leak not allowing the blend flaps to work properly.
Offline Skunksmash
« Reply #10 on: May 27, 2011, 05:22:35 pm »
Hmm... where would you recommend looking for that vacuum leak? Vacuum leaks are probly easy, but I've never been good at them. I have no idea where all they ran vacuum lines on these old trucks.
Offline Grim 82
« Reply #11 on: May 28, 2011, 12:14:26 pm »
Start at the reserve can on the firewall and trace that hose back to its source and make sure that it's hooked up and fits tight. I have mine hooked directly to the carb.
Offline cvbear
« Reply #12 on: May 28, 2011, 01:26:07 pm »
I have AC issues as well, I am curious as to why you have the vacuum hooked directly to the carb and not to the canister.
Offline Grim 82
« Reply #13 on: May 30, 2011, 03:57:17 pm »
I have the canister hooked directly to the carb instead of having a fitting threaded into the intake manifold. The only lines I run are directly from the carb. PCV, brake booster, ported to the vac advance, and manifold to the HVAC reserve can.
