Wheels & Tires
wheel hub size
Topic: wheel hub size (Read 11183 times)
74chev4x4
wheel hub size
January 02, 2011, 10:18:36 pm »
Hey guys buying some wheels and tires off of CL for my 75 chevy 4x4 with dana 44. The wheels are 16" stock GM wheels from a 89 k2500. My question is will the hub size clear my hub on my front axle the part that the hub goes through. If not no big deal because the tires are bfg at 295/75/16 and I can put them on my current wheels otherwise, just got to thinking, thanks.
Re: wheel hub size
January 03, 2011, 05:33:15 am »
Don’t think so. Since they went to independent front the hubs are smaller. could be wrong but im pretty sure
74chev4x4
Re: wheel hub size
January 03, 2011, 06:48:44 am »
OK I hear ya there Irish, I was thinking since its a 3/4 ton truck wouldn't the rear axle hub stick through also and that is a pretty wide hub too for the rear. Might not be thinking about it right though its 4:30 am here? Thanks.
74chev4x4
Re: wheel hub size
January 03, 2011, 06:50:00 am »
anyway what do you guys think for a set of 4bfg at tires 295/75/16 2-95% tread and to are 50% tread still worth it for just the tires.
Re: wheel hub size
January 03, 2011, 10:41:44 am »
Might be ok deal thn turn around and sell the rims or scrap them I got 10 bucks for a aluminum one
74chev4x4
Re: wheel hub size
January 03, 2011, 11:36:16 am »
Forgot to mention,$220 for all 4, seems good to me?
756man
Re: wheel hub size
January 03, 2011, 11:02:07 pm »
The wheels will fit fine.
1985 Chevy K-20 longstepside, 350,Turbo 400
Re: wheel hub size
January 04, 2011, 08:10:45 am »
Also they came with 6 lug. Here's my grandfather's 89 I know its the rear but look how small the hub is
and that much for used tires no I wouldn't do it just for them
fitz
Re: wheel hub size
January 04, 2011, 10:55:08 pm »
The 88+ 2500's came in both 6/8 lug set patterns.
The rims from my 2000 2500 (8 lug) will not bolt up to the 81-87 8 lug pattern.
As Irish pointed out, the center hole is to small.
Wheels & Tires
wheel hub size
