Author Topic: Easy way to remove front bumper  (Read 19977 times)
Offline JTESTER
« on: January 06, 2011, 01:17:36 pm »
i have an 83 gmc sierra classic and i need to take my front bumper off to primer the front of my fenders but i cant get it off, an suggestions to get it off?
Offline Grim 82
Re: Easy way to remove front bumper
« Reply #1 on: January 06, 2011, 01:20:28 pm »
Remove the bolts.
Offline Da67goatman
  • Burban
« Reply #2 on: January 06, 2011, 01:22:41 pm »
Rubber BFH
<Pitcrew>
Offline JTESTER
« Reply #3 on: January 06, 2011, 02:52:37 pm »
sorry for not bein detailed, thats the problem the bolts are rusted up and they won't turn at all and i cant get a good angle on em to try and put some power into em
« Reply #4 on: January 06, 2011, 03:10:50 pm »
Soak them in PB Blaster
Offline Grim 82
« Reply #5 on: January 06, 2011, 03:24:34 pm »
Get a short socket and a long breaker bar and tighten them til they snap. It will be easier in the long run.
Offline hotrod24
« Reply #6 on: January 06, 2011, 04:40:28 pm »
You could also just unbolt the bumper brackets from the frame instead of unbolting the bumper from the bumper brackets  ;) and then when you have the bumper off take the bolts out or cut them off...
1978 pontiac grand prix...
« Reply #7 on: January 06, 2011, 07:52:03 pm »
     That way even if the bolts on the frame are rusted, you have space for leverage.
Offline jmj6879
« Reply #8 on: January 13, 2011, 08:09:16 am »
Use an impact gun and take the bolts of at the frame. It's too easy to destroy the bumper with the impact but it should be pretty quick taking them off at the frame even if it's rusted. If that doesn't work, you can heat them first with a small propane torch if you have one or go all in and burn them out with an oxy/acytelene setup. But I'd be surprised if the impact didn't work.
Jake
Offline Laderhosen
« Reply #9 on: January 13, 2011, 08:13:28 am »
'82 3/4 ton, 350, th400,
'88 K5 Blazer, 350, 700R4
’98 BMW 328i daily drive
Offline biscuit41
« Reply #10 on: January 14, 2011, 08:51:06 pm »
+1
It was easier removing all the bolts with the bumper off the truck.
1985 C10 Longbed
Offline Jim Rockford
  • Banned
« Reply #11 on: January 16, 2011, 11:14:22 am »
plasma torch
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Offline 87454westernhauler
« Reply #12 on: January 31, 2011, 09:11:08 am »
chop saw angle grinder!!!!
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Offline autorepr
« Reply #13 on: January 31, 2011, 12:22:04 pm »
My personal fav, the red wrench. (Blow torch) I carefully take all kinds of stuff apart with it!
