Author Topic: Rust around the side rear window and A pliiar  (Read 6531 times)
Offline harkz28
« on: January 09, 2011, 07:46:38 pm »
What is the easiest way to stop rust and repair it at home. (no welder)  I have rust around the rear side windows (Suburban) and on the the A pillar.  Is there some special Bondo product I could use? Thanks Steve
Re: Rust around the side rear window and A pliiar
« Reply #1 on: January 09, 2011, 07:48:33 pm »
You need to remove the rust and are we talking rot? Pix?
Offline harkz28
« Reply #2 on: January 09, 2011, 07:50:57 pm »
Yes I guess you could say rot. Will post pics later. Thanks
Offline harkz28
« Reply #3 on: January 13, 2011, 09:49:05 pm »
Nasty rust
« Reply #4 on: January 14, 2011, 08:40:39 pm »
Take the glass out and start wire wheeling to see how bad it is.
Offline harkz28
« Reply #5 on: January 14, 2011, 08:55:13 pm »
Will do!!
« Reply #6 on: January 14, 2011, 11:16:45 pm »
     If the rust has eaten to much of the metal to support the window you will have to replace the metal.
Offline harkz28
« Reply #7 on: January 15, 2011, 07:45:37 am »
Does anyone sell patch panels?
« Reply #8 on: January 15, 2011, 09:36:13 am »
Just remove the rust and see what you've got. If you need a patch panel either make one or post a wanted to buy in the classifieds and someone with a parts truck should be able to help you out but it doesn't look that bad from the pix. You won't know until you expose what's there.
Offline harkz28
« Reply #9 on: January 15, 2011, 10:36:42 am »
Sounds good thanks !!
Offline Jim Rockford
  • Banned
« Reply #10 on: January 16, 2011, 11:13:21 am »
Don't be surprised if its more than it look like now, Rust is like an Iceberg. alot more under the surface than on top.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
