Overheating Problem
Topic: Overheating Problem (Read 13332 times)
Slammed83
Overheating Problem
January 12, 2011, 02:46:55 pm »
I went out this morning and started my truck up, and it got to about 180 like normal so i took my sister to school. I had the defrost on the whole time and the heat never really kicked in. And then i was about 3 blocks away from her school and it started to overheat really bad and climbed the gauge to about 240. I shut it off and checked the antifreeze, added a little and started it again about 10 minutes ago. The gauge went right back to 240... So can someone tell me what is wrong? im not too bright when it comes to the cooling system..
beastie_3
Josh
Re: Overheating Problem
January 12, 2011, 02:56:49 pm »
When the coolant is cool, open the rad cap and see if there is coolant flow. The pump might have gone out.
Semper Fi
screamin86
January 12, 2011, 03:35:10 pm »
Possibly a bad thermostat also!
86 ta:lm7 hot cam boltons
Slammed83
January 12, 2011, 03:37:10 pm »
Thermostat was my first thought, But there actually isnt any coolant flow because none of the Heating hoses are warm.
Jim Rockford
Banned
January 12, 2011, 07:34:01 pm »
yup . thermostat is stuck closed , really low on water, or you didn't have enough antifreeze and you radiator was frozen . Never add cold water to a hot engine with it off, and if its over heating do not remove the cap. just hang out and wait for it to cool off and then add water after you get the cap off and then start it up and add coolant.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Slammed83
January 12, 2011, 08:43:11 pm »
It was at 240 before i realized what was happening, So i pulled over and let it cool off.. Then drove it home. I let it cool off for 5 hours while i slept off my cold then went out and it was low on coolant so i added some. It still went up to 240 and i noticed that there is no coolant flow.
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
January 12, 2011, 10:30:57 pm »
t-stadt
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
screamin86
January 13, 2011, 01:36:36 am »
Fail safe all the way!
1980c10
January 13, 2011, 06:15:10 pm »
check the weep hole on your water pump while your checking stuff.
86k20
January 13, 2011, 06:35:58 pm »
could be a bad water pump and a thermostat
Slammed83
January 13, 2011, 10:47:06 pm »
I changed the Thermostat and water pump today, Somewhat fixed the problem, Im looking into the radiator not getting cooled by the fan efficiently..
1980c10
January 14, 2011, 02:39:08 am »
It could also be that your radiator is partially plugged.
If it overheats while driving suspect your radiator.
If it overheats while not driving (at idle) suspect your fan.
If you are still losing coolant you may want to pressure test the cooling system.
Slammed83
January 14, 2011, 03:33:05 pm »
Alright. I think its the fan.. I was drivin this morning and it was at 210.. Sped up to 60 and it dropped to 180
beastie_3
Josh
January 14, 2011, 04:51:26 pm »
How long have you owned the truck?
Did you remove the fan shroud?
I have never had a shroud on mine as long as ive owned it and my flex fan is about 4 inches away from the radiator. Ive never had a problem with it overheating.
Semper Fi
Slammed83
January 14, 2011, 05:07:45 pm »
Bought the truck this past may, No shroud. It runs 190 on a hot august day, but i dont get why it would go to 220 when its -2. It is heading fine.. Maybe the radiator is just too small?
Overheating Problem
