Author Topic: Clutch Pedal Stays On floor  (Read 3334 times)
Offline 86silverado
« on: January 15, 2011, 05:28:52 pm »
Went to drive truck the other day and pushed clutch down started truck and pedal stayed there, acts like it has no pressure at all, has hydraulic slave cylinder and manual throwout bearing,   Im sure its slave cylinder,(which was just replaced not that long ago, but just because its new doesnt mean it cant break)  is there anything else that could be wrong other than the slave cylinder?
Re: Clutch Pedal Stays On floor
« Reply #1 on: January 15, 2011, 05:45:18 pm »
Did you check the fluid in the clutch master cylinder??
Offline 1980c10
« Reply #2 on: January 15, 2011, 05:57:59 pm »
clutch cylinder, slave cylinder or the line connecting the two could be bad. It may also need to be bled and fluid added.
Offline 86silverado
« Reply #3 on: January 16, 2011, 12:03:30 pm »
yeah i checked fluid and it was still full, throwout bearing was makin noise before, that mighta went bad too
« Reply #4 on: January 16, 2011, 12:10:29 pm »
If you bled it and it's not building pressure replace the master.
