350 build questions
Topic: 350 build questions (Read 7595 times)
74chev4x4
350 build questions
January 15, 2011, 05:39:33 pm »
Looking for some advice from the guys on here that know a lot about building these chevy 350 motors. I am looking to rebuild one for my 74 k20 because they $400 one I have in it is not reliable enough anymore. I know I can go buy a goodwrench for $1600 and have it in the truck by tomorrow, but enjoy building motors and like learning all this stuff. This will be my first chev 350 rebuild. Wanting to build a motor that has good torque for pulling a small boat or trailer, but that I can also drive to work a few times a month and get 11 or 12mpg, I think thats fairly reasonable. What types of kits are good to buy, I have heard vile mention the summit parts being good. What type of cam would be good. I have already talked to my machine shop and got an estimate of about $500 for work on basically everything but heads. Was thinking on buying some new vortec heads, but am open to suggestions on other stock chev heads. I have a factory service manual, haynes, and have built a few 4 bangers before. Any suggestions would be great. Thanks.
1980c10
Re: 350 build questions
January 15, 2011, 06:13:04 pm »
here's my current 350 thread
http://forum.73-87chevytrucks.com/smforum/index.php?topic=18146.0
I am going to have this engine dynoed next week so check back and I will post results.
Hope this helps
74chev4x4
January 15, 2011, 06:58:16 pm »
Just read your build, lots of good info in there. I might stay away from the vortec heads though, they seem like kind of a headache to get all the right stuff together to make them work.
January 15, 2011, 07:14:46 pm »
Not much of a headache but be prepared to shell out $1200 bucks or more for good comparable heads.
74chev4x4
January 15, 2011, 07:30:05 pm »
Was hoping you would chime in vilezambonie, I really respect what you have to say and any advice you can give. I guess the different intake and valve covers are not much of a headace for me, but I get confused if I was to buy a new set of vortec heads I need different rockers for them and I'm not sure where to get them or what self aligning rockers are? What pushrods do I run with them also. Can you recomend a good engine kit that would work well with the vortec heads to achieve a good reliable 350 with some torque( what kind of pistons, cam?) Thanks.
CanadianC10
January 15, 2011, 09:46:51 pm »
flat top pistons and a low end cam would be good for your usuage .. give you lots of lugging power for hauling a boat while keeping your Rpms down and your foot of the gas
and im going with vortec heads , seems like there pretty popular
1984 C10 LWB
CADDY 507
TH400
Frame twister
12.59 @ 108 .. 1.94 sixty
74chev4x4
January 15, 2011, 10:14:42 pm »
OK good info thanks. What would you consider low end for the cam. I have been looking at the rpm levels and you can get some that start at idle to 5000rpm, I am running a turbo 400 trans so no overdrive.
1980c10
January 16, 2011, 12:04:55 am »
self aligning rockers are stock equipment with vortech heads but after market is ok too, just make sure they are self aligning. I had the machine shop assemble the engine block and heads with rockers and pushrods to avoid any confusion on my part and to get a warranty on the engine. I considered this worth the extra money. I was lucky and bought a set of ready to use low mile vortech heads for $125 and some aluminum valve cover for another $25. and the intake was $200.Considering I would have gotten a differant set of heads, intake and valve covers; I am probably not out any extra money. btw I did have the heads gone through just to make sure.
74chev4x4
January 16, 2011, 10:57:45 am »
Can't seem to find these rockers anywhere, will keep looking. I am going to put the whole moter together myself, bought a dvd and two good books on how to rebuild one and ive got u guys if all else fails.
bobcooter
1979 Scottsdale C-20
January 16, 2011, 11:47:28 am »
My 350 is bone stock except for a set of flat top pistons. I had headers, 882 heads and a Summit Stage 1 intake earlier. It makes a lot more tourque with the stock set up and flat top pistons than it did in the other configuartion. The other way had more horse power. It is in a 79 C-20 long bed with 3:73 gears and a TH-400. I get 12 MPG constantly even running the AC. I sometimes wonder about the factory cams vs aftermarket cams. The factory had to do something to these engines for them to make good tourque with the low compression engines. I think the cam must be a good grind. You can get an RV cam if you really want lots of torque.
I like my setup now. I have extra power and torque and some reliability.
Don't waste your money on the 882 heads. They are bad to crack if you run them hot. One of mine did.
TexasRed
January 16, 2011, 12:27:54 pm »
Self-aligning rockers:
I've never used CNC-motorsports stuff, so at your own risk:
http://www.cnc-motorsports.com/product.asp?ProdID=14970&CtgID=27630
Summit racing:
http://www.summitracing.com/parts/NAL-12495490/
http://www.summitracing.com/parts/CCA-1417-8/
January 16, 2011, 12:41:33 pm »
Why not buy a vortec 350 used and build that? It's already set up with Vortec heads and a roller cam. I found the one I just built for one of my trucks for $100 on Craigslist.
350 build questions
