Author Topic: sb heads?  (Read 5173 times)
Offline tigwelder
sb heads?
« on: January 19, 2011, 09:19:47 am »
have a 77 k20 with 400sb. can i run 350 heads?
Offline topp
Re: sb heads?
« Reply #1 on: January 19, 2011, 09:35:51 am »
I believe they would need to be drilled for the steam holes the 400 has....
'90 Suburban TBI 350
Offline Jim Rockford
  • Banned
Re: sb heads?
« Reply #2 on: January 19, 2011, 12:46:34 pm »
really not an upgrade unless you are planning on vortecs or aftermarket head
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Re: sb heads?
« Reply #3 on: January 19, 2011, 01:08:26 pm »
You have to drill the heads for the steam holes for it to work.  What are you hoping to accomplish?
Offline tigwelder
Re: sb heads?
« Reply #4 on: January 19, 2011, 05:43:30 pm »
my brothers plow truck.running ruff . guy he knows has friend who had a new set of 350 heads off crate engine and after doing a compression check decided to replace heads with the 350 heads.then he calls and tells him he found out the heads had to be drilled.he didn't know what to do and is just trying to get this truck to last for 2 more months.so he ask me what i thought and i have no idea. that's is why i ask.
Offline thirsty
    • Suitor's Garage
Re: sb heads?
« Reply #5 on: January 19, 2011, 06:25:24 pm »
Pull the heads and have them redone maybe??? Then you don't have to purchase and modify.
Offline tigwelder
Re: sb heads?
« Reply #6 on: January 19, 2011, 07:27:41 pm »
its already back together and he has been driving it for a couple days no heating problems yet.plowed with it today for 6 hrs.
Offline chuck13
  • no matter where you go,there you are
Re: sb heads?
« Reply #7 on: January 20, 2011, 02:45:49 pm »
i'm running 350 heads on my 406.just used the head gasket as a pattern for the steam holes.
its been together for 5 years with no problems.
