73-87 Chevy & GMC Trucks
79 chevy driveshaft
Topic: 79 chevy driveshaft (Read 8004 times)
79 chevy
79 chevy driveshaft
January 25, 2011, 06:52:17 pm »
I broke my rear drive off. I just found one on a 3/4 ton gmc. I was wondering if the drive out of that 3/4 ton would work in my 1/2 ton. It bolts on the same and everything. not sure if everything is the same the guy said if i take it off i bought it so i kinda wanted to know if it was the same. Thanks
Last Edit: January 25, 2011, 06:54:01 pm by 79 chevy
79 Chevy 4x4
Stock for now:)
choptop
Extended cab fanatic
Re: 79 chevy driveshaft
January 25, 2011, 07:26:19 pm »
I was thinking that the 3/4 ton u joint was larger than the 1/2 ton. Not sure tho, but a tape measure would answer it quickly.
beastie_3
Josh
January 25, 2011, 07:45:35 pm »
If it works, throw some new u joints in and get it balanced. Maybe new u joint straps as well.
Semper Fi
bobcooter
1979 Scottsdale C-20
January 25, 2011, 08:15:59 pm »
The u-joints on the 3/4 ton are bigger but you can buy some crossover u-joints at NAPA. They have 1/2 ton on two ears and 3/4 ton two ears so you can mate it with your rear end. Measure the length of both driveshafts and compare to see if they will swap. there are several different ones out there.
bake74
January 25, 2011, 08:23:26 pm »
Bob Cooter is right, I have an 81 k10 that has 3/4 ton axles on it and that is all I had to do, change u-joints to fit.
74 k10, 77k10 Tom
79 chevy
January 25, 2011, 08:26:38 pm »
cool thanks guys
79 Chevy 4x4
Stock for now:)
79 chevy driveshaft
